  • Replies 47
its pretty common around my area to see the boys in dere magnas lol... its rather funny when they really think that they have a chance...
what i dont get is people go out spend god knows what on a standard lancer magna etc... put massive kits on it 17/18" rims that are chrome usually black tints and the typical stickers displayed on the back window and think they are driving a sports car after they have just spent anywhere between 18k and 25k in total to have a riced up magna/lancer that really never sounds any good... just go out and buy a god damn sports car... seriously
i dont have the rims or really many mods just basics. my car is pretty much stock and yet they still feel the need to take me on...
as for a previous comment about a girl in a black series 2... just goes to show how immature she really was and you can only bet she doesnt know what she is doing...
/end rant
Edited by Disko_Tek
I have a manga, fire blue :( , awesome condition, late 1978 release, after market goodies include;
Momo steering wheel
Stainless exhaust tip
HKS Air Filter
recent oil change
Sony cd stacker (with surround sound speakers)
Its not quite as nice as the above mentioned Verada but it certainly pulls its weight down around the track. Took it to Barbagello, did a 3:13:58 on my third lap. Quite impressed. I know everyone bags us manga boys and alot of the time for fair cause but there are a few of us out there that aren't idiots, I am here to tell you I am one of the acceptable few.
If you guys have any questions give me a shout. Will try and get some pictures up soon for your viewing pleasure!
Peace out
Guest
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
