  • Replies 90
Posted Images
While I was competing at the comp I heard about this, thought it was completely shit... punishing people who took the time, money and effort to compete legally in a sport they love... f**ked.. at least by the time we left the track at 8 there weren't any still around..
Some cops are a bit overzealous, for want of a better word - but please guys, you must realise, if they get calls because some tool has been watching drift and decides to start carving up the roads around where people live OF COURSE the police will come out. If they didnt, then people would be complaining the police are doing nothing.
If you really do think you are getting the short end of the stick - and lets face it, alot of people do, then complain to your local MP - they can actually do something.
And if you are worried about getting defects - go and get permits. I got permits for all my mods, and my car is pretty heavily modded - very cheap peace of mind for a whole $37.50. Alot cheaper and easier than screwing around getting stickers removed.
Usually, its a few tools out there on the road that make everyones life harder.
*giggle*
your funny
hope you have your permits laminated to save them tearing them up in front of you..
they also tend to not pay attention to permit regardless and still sticker you..
Theres an application form for major mods that you can pickup at the pits.Minor stuff just take the car to the pits.I got an MX5 approved with an F355 Ferrari motor and trans fitted in the rear(Cars about to get finished)but had to have flex tests etc but we got it passed so near anything is possible.
No, your right, much better to not get permits then bitch when you get defected for something you could of got a permit for.
and yes, they are laminated.
Permits don't do squat 99% of the time, most cops don't believe in them and just ignore the fact you have gone to the effort to do things by the book..
ivew also had friends have permit paperwork torn up in front of them by police when pulled over, and shown them the permits for everything..
Oh man I really didn't miss this while absent from the forums.
No reasonable cop would rip up the permits in front of you if you yourself are being reasonable at the time. If they do, then take there badge number take a pic on your blinged out camera phone and report them. A cop will only do something if he knows he can justify his/her actions.
Any of you who are now saying to yourselves "I wouldn't want to do that - they may do me in for more things on my car etc etc". Then you were probably caught doing something overtly stupid, gave a bit of lip and deserved the treatment you received.
Grow up kids - stop acting like such victims!
........keyboard hero awaiting feedback :)
It comes down to the reason you were stopped and your attutude.
Ive driven modded cars for 24 years and only ever got a sticker once and yes i was being silly and smart mouthed and that was in 1984 and i learned from that and have had no problems since.
Guest
    • She swallowed the spider to catch the fly.
    • Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
