hey guys hopefully this isnt a double post... but anyone looking for cheap coolers there is an offer on Antilag in the for sale section
I just picked up a kit today.. it all looks in order..
piping/hoses/clamps/cooler $400
just wanted to put it out there incase anyone was planning on getting one
https://www.sau.com.au/forums/topic/113671-cheap-cooler-kits/
go to antilags for sale section.... says there are kits for 32, 33 and 34...
most ppl here got 32's and 33's anyways..
when i fit one to a 34 i will let you know if its any good..
don't suspect any dramas
noise...you had any problems specifically.?
only thing i know of is the bracket attached to bolt to the block, needs to be modified a little to bolt up...even then, it doesnt really even need to be bolted once its all joined.. thats all i know of.. if you know of something else.. enlighten.. before too many people rush out
r34 has the washer bottle in the way and different distances to things. I came down to the workshop with my car pulled apart and he showed me all the parts not lining up.
He also told me he has seen plenty of kits that just dont fit, saying that, some must fit or there wouldnt be a market for them.
This is all from a "reputable" if there are any, workshop in perth.
The china kit i bought came with instructions and pictures for an r33 even though it was sold for "r34". The instructions included bending the chasis slightly and didnt say what to do about the water bottle.
I ended up returning the kit and getting a full custom stainless steel install.
full custom stainless installed is only a few hundred more then china kit installed, if you pay a workshop.
just a warning from my experience :)
Edited by noise
oh yeah the washer bottle, i read that on satanics website.NSW member.
i hope it at least semi fits.. shouldn't be a big issue either way.. i did stainless piping on the satria conversion and that was fairly straight forward.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
    • Good question, I don't really know tbh...I'm pretty stock thought, where could I check this?
    • This. I'm confused by the whole discussion. The only reason you would have a car with e85 only if it was track use and you only ever used e85. All other use cases you add a flex fuel sensor, do the flex tune (you only need to do a couple of % and then interpolate the rest) and then you put whatever the hell you feel like including a mix in the tank and it just works. Want a long drive? fill with 98 Want max zoom? fill with e85 Got a half tank of 98 then find e85 somewhere? Throw it in.
