Hey Guys,
I'm a long time reader but never posted much on this forum. I will be flying up to brisbane this week to buy a GTR and am undecided as weather or not to drive it back or just get it shipped. The actual driving doesn't worry me it's more will the car be alright doing the trip. The car is modified and has recentley had an engine rebuild.
Any opinions would be greatley appreciated.
https://www.sau.com.au/forums/topic/113676-long-distance-driving/
I've done the Brisbane-Sydney drive with an unknown modified car before and was fine. You have twice as far to go, so may be a bit hairy.
I suggest that maybe you don't even have enough time to book freight? Can you? If not, you may be forced to drive.
Go the pacific hwy(as opposed to the New England hwy), as there are more well equipped towns along the way to help out should you have a problem.
Yeah I have already organised it to be covered by the racv who covers nationally through nrma and such. My thoughts were to just run a very low boost setting and take it easy.
Freighting it wouldn't really be a problem I have somewhere to store it indefinatley in Brisbane, I just haven't been able to find a freight company that either specialises in these type of cars or I would trust to move it.
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
    • I wonder if part of it has to do with when you've each bought the kits. I honestly have the feeling that the silicon joiners in the 2000s were actually better quality than most of what you can find these days. Even in the same brands. Everyone racing to the cheapest price while still trying to make profit means lower quality parts. For coolant, I personally would be going with rubber, OR, converting the radiator and engine to use the huge AN fittings hose for radiators.
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
    • Is it oil smoke or fuel smoke? They smell different.
