Hi all im wondering where would the best place to locate a 4 channel amp in my R33?? im not going to be using a sub woofer just decent quality speakers all round. Also im after nice sounding set up with a good balance of treble and bass which would sound nice and clear from outside. not a fan of sub woofers. what speaker would you suggest I use for the front and rear. I was thinking those cool pioneer splits the yellow ones 6.5 inch for the front any good?? your advice would be great thanks.
https://www.sau.com.au/forums/topic/113677-r33-amp-location-set-up-advice/
  • Replies 46
Those Pioneers are ok, the tweeters are a bit harse for my likings, but on the whole they are not too bad. The crossover may have an attenuation switch to turn down the tweets a bit if you go for the components.
Other than the Pioneers, I'd recommend Infinity, Focal, PBX, Soundstream, DLS...etc. There is a huge range of brands out there to chose from, but a good solid installation can make or break how the end result will sound. How much you wanna spend on them will also be a factor. Try to listen to a few and see what your ears like.
As for the amp, I'd suggest you mount it on the tray next to the battery under the parcel tray. That way you keep all of your boot and the amp is hidden from prying eyes. Also, If your battery is in your boot like most R33's, then you won't have the trouble of running much power wire.
Also, why are you after clear sound from the outside of the car? You planing on using it as a stereo for mates to listen to while hanging out? If you plan on listening to it for long lengths of time without the motor on, then I'd suggest you check your battery has a decent capacity to keep it powered.
Hope this helps.
yeh it does help alot. I just want a nice sounding system which is clear not distorted like heaps of systems ive heard on the street which sound terrible. Im going to check out this location now for the amp and make surei buy one which will fit nicely. ive been told infinity component speakers are awesome. I know a real good installer so should be good.
Edited by LatinR33
if you want great sound then a set of high quality splits and a high quality sub with a quality amp are a must.
send an email to FHRX on this forum. he will be extremely helpful.
alternatively talk to the good installer you know and ask him about well sorted subs. i would never be without one since i bought a YST-800 at home several years ago. cars are no different. there is so much more warmth to music when the crossovers and the gains are set in 'your' own personal' sweet spot.
the amp can be mounted under the floor next to the space saver if you are looking for another location.
i have the pionners in my capri and they are good you just need a good amp to drive them and have a good H/U with decent pre outs. i also would tell you to go into a car audio should and listen to all the splits they have and get them to run them off the amp you will by and the h/u if you can.
I have reloctaed my fuse box that is next to my battery to accomodate my sub amp, it's a fairly easy task, apart from having to take the back seat out :D
Yes, infinity are a favourite brand of mine, although there are a fair few better brands, I find infinity a good balance of bang for buck. At the moment I am runnig a full Infintity system. If you can afford the Perfect 5.1 or 6.1 components, they are the ones to have. Unfortunatley for me they do not do a nice 3-way components set, so I have settled for old Kappa 3-way setup. If your budget doesn't allow this then some of these infinity models should do a good job for you
60.5cs Kappa series. Older model, you may find cheap run out stock of these components.
60.7cs Kappa is the replacement for above model. These are 2ohm speakers, so essentially, you will get more power out of your amp to power them.
The models below these are Reference series, but if you can, stick to Kappa and better.
Again, if you can listen to a few different speakers in store, this will give you a general idea of how certain speakers sound. Unfortunatley, they will probably sound rather different once installed. This is generally because a car is a real shitty enviroment to try and produce nice accurate music from. Steering wheels in the way, resonating metal panels, sound wave reflection off interior materials etc etc.
Sound deadening will make a BIG improvement to your system also. There are top of the line brands out there like Dynamat Extreme, which although fairly expensive, it is renowned as one of the best brands out there. More bang for your buck would be something like 'Automotive Sound Deadening Panels'. Over here in NZ we have a brand called Bostik which makes these bitumen based (I think) panels. They are heated up so they become plyable, then a wax paper backing is pulled off and an adhesive surface is exposed for you to stick onto your door skins or other panel you choose to treat. For arond $100 for 10 x 500mmX500mm panels, this is a great investment. Installing on the inner and outer door skins will help you produce nice crisp/strong mid bass from your drivers.
Have a look at this website for more info and tutorials on sound deadening and other ways to improve your system - www.nzicemag.co.nz
Cool very informative. Im just going to go for the 4 speaker set up not sub. Keep the weight down as much as i can. I also been told the rears on a R33 are 6.5 inch's for a direct fit and the fronts are between a 6inch and a 6.5 inch this makes finding fronts hard. anyone have pics of their in cabin 4 speaker set ups?? would be great to see what other fellow skyliners have done.
nice set up.. but see where ther amp is right??? wats the metal thing underneath it?? cos my r33 doesnt have that???
i see thats coolz.. i want too design sumthing similar but with 2 levels for 2 amps and have it on a angle for abit of show lol
how much did the material cost u?? and wat material is it?
  • 1 month later...
Would you have any pics of where you relocated the fuse box to? I might have to do this too because I really want to place the amp I just got in that spot near the battery. There isn't enough space as it is.. need roughly 2 inches more.
An alternative I've been thinking about is possibly moving the entire tray that holds the battery and the fuse box over to the left a bit. That would give me enough room though I'm not sure how easy it would be. :D
After much thought, I think i'm just going to buy a shorter amp. Relocating battery tray means drilling new holes, and welding a nut on the other side for the thread...
Putting amps under the floor means making up a false floor...
All too difficult!
I'm with you there RANDY! ... although the problem I have is that I already bought my amp :P .. and I don't particularly want to change it now.
I think I'll have to go with a setup like d00dz has. It looks good and doesn't really take up any boot space. My only annoyance with it though is stuff in the boot that will keep on hitting the amp potentially scratching it, or worse, damaging the cables. I suppose one could just make a cover for it.
d00dz, I take it you just used a piece of carpeted mdf or similar for the panel that you've bolted the amp to? Where did you get the matching carpet from?
Just some boot carpet, from audio car shop lol. I asked them they had some. :P
Make partitions of MDF at the bottom so that the stuff in the boot wont move around.
My sub moves around in the boot havent had time and cbf'ed to make it secure. Yeh I used MDF panel, u can see the brackets I used.
damuscat: I have already made up a rear section like doodzez one, with brackets to have the little bit on the right hand side at a 30 degree angle or so.
The factory mounts for that battery cover are not strong enough, so you'd have to do all those mounts like doodz has done. Drill holes into your parcel-shelf, mount brackets, rivet them in place etc etc.
Even then, i'm looking for a stock look. I want to get to my spare tyre without ripping the whole lot out, and get to the battery with the same ease.
I have made a new floor out of masonite, the full size of the original carpet, then glued the original carpet on. So I don't want to make up a whole new floor.
I was going to mount my Sony 12" in the battery cover bit that I made, with the magnet-end poking into the empty space next to the battery. This would have looked wicked, but alas, there are no simple mounting options. =-[
So, i'm sticking with my good 6.5" speakers, and swap to a small 4x100w amp next to the battery, and then calling it quits.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
