Hey guys, I been reading up and apparently the series II RB25det's have NVCS which is like VVT/VVL.. and also apparently it is controlled by a solenoid somewhere on the engine... at the moment, untill I hit 4500RPM, the tourqe is nothing special.. but from 4500 to redline you get a huge rush of power!! its even noticable on my dyno graph...
Heres my question... is it possible to to have the solenoid always 'on' so that you have the advanced timming on bottom end too?? or to even connect a switch to it similar to the "high boost mode" idea???
Anyone got a pic of this solenoid??
Regards,
Sarkis
https://www.sau.com.au/forums/topic/113681-rb25det-nvcs-concept/
the VCT solenoid is the hexagonal thing coming out of the side of the head near the end of the fuel rail and the water outlet...
its a simple on/off solenoid which allows oil to flow into the unit on the end of the cam shaft, and change the advance/retard on the cam.
i actually believe that its "on" from about 1500 to 4500 and OFF before and after that.. so you actually sound like you want it off.
you can do a run with the solenoid unplugged and see if it helps your results, but i dont think it will..
im doing a kick off point rpm test at our next dyno day for the NVCS on the rb25. you do a dyno run with stock setup (kicks off at 4500) then plot power w/rpm. then turn nvcs off (make it kick off at say 1200rpm) then dyno run again. plot it on the same chart and the point where the two intersect is the ideal rpm kick off point. im not sure how useful it will be (if anything at all). but still something fun to try.
powerfc users can alter the kick off point via datalogit
right so it does vary a bit on each engine, sweet as.
in the powerfc i can only change the rpm point.
so it comes on always at about 1400 and then off again at 4500.
so you found the ideal kick off point is near 5500 once tuned ?
More linear power curve. If the cam changes to soon you can loose power and torque,if you can changes at 4500 and it needs to be at 5500 for example then you are giving up max power for 1000rpm right in the guts of your curve. Do a power run with the vvt off then do one with it on from start to rev limit and its easy to see where to switch at.
LINKS - Im currently running the Hi-Boost mode on my factory solenoid therefore constant 7psi... my car is fairly stock except for the split dump and 3" hi flow CAT and exhaust + K&N Pannel filter (165rw/kw) and at 4500 - 5000RPM i get a slight pop (at times) from the exhaust and a rush of power to redline! Its not a misfire for sure cause theres no hesitation and the coils + NGK plugs are only 6 months old.. Im definate its the NVCS kicking in via ECU and CAM gears... all i was hoping to do is get it kicking sooner to get more bottom end... i guess ill need an aftermarket ECU...
Do you guys think resetting my factory ECU would help after getting the exhaust or any other mod fitted?? any benifits?
Cheers
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
