don't worry, r32 oil pressure gauges are often faulty and read wrong.
Every R32 i've seen including mine either reads wrong or just doesn't move at all, and i've checked heaps :bunny:
You only have to worry if the little red light comes on :D
https://www.sau.com.au/forums/topic/113699-no-oil-pressure/#findComment-2095488
its not the actual gauge. its the oil pressure switch. get it changed soon or go get an aftermarket oil pressure gauge which comes with its own oil pressure sender which replaces the standard one.
this is a common problem with 32's.
https://www.sau.com.au/forums/topic/113699-no-oil-pressure/#findComment-2095843
i had the same kinda thing on my r33 recently.. once the car was pretty hot the gauge would randomly show it at 1psi for a while.. i soaked the electrical connector on the back of the oil sender in contact cleaner and it hasnt stuffed up since..
I think in my case though i had spilt heaps of oil on it when i took the oil filter off last time :(
https://www.sau.com.au/forums/topic/113699-no-oil-pressure/#findComment-2096016
The sender is quite easy to remove.. get a 17mm spanner on there, and unscrew from behind.. if you jack that side of the car up, it shouldn't leak any oil out the block.
Screw in new or replacement sender. Probably best off with an aftermarket gauge when you're there.
https://www.sau.com.au/forums/topic/113699-no-oil-pressure/#findComment-2097526
Yeah mine just stays below 4 all the time, good to know this is common and not much to worry about :(
i'd still go and get your sender replaced to make sure. its not something you want to take a gamble on.
justjap sell oil pressure gauges which include the sender in the pack for $50. cheap insurance if you ask me... very cheap.
https://www.sau.com.au/forums/topic/113699-no-oil-pressure/#findComment-2099646
in my 32 gauge reads about 4 on start up and once warm reads almost 0 then 0. been told to replace oil pressure sender, yeah common problem.
Mine used to be fine, alway on 4 or just under, Last week i noticed that when i start the car it reads about 4 and once warm reads almost 0. Same as yours. I think i might get a oil pressure gadge and test it out next week.
https://www.sau.com.au/forums/topic/113699-no-oil-pressure/#findComment-2130056
