i reckon its rated at 85 ron hahahahha!
Can you use it? well that depends. when you open your fuel cap, does it say "Premium unleaded only", or does it say "put some water, kerosene, metanol, ethanol, paint strippers, piss, milk, **** put anything in if you dont give a shit about how your engine runs or if it lives"
If its the second, then go for it!
Would you shop at Wollies for your engine oil?
Anything that is price driven has quality issues from the start in order to remain profitable!
You get what you pay for and if your not carefull you'll end up paying for what you get.
p.s. Optimax tastes the best!:D
Originally posted by ed
the woolies servo we met @ for the bobbinhead cruise had premium 98 rated fuel.
No idea how well it is though.
Really? i didn't realise they sold that....well there ya go...
i haven't gone near a woolies servo since i got the Skyline, I just assumed they didn't have any 98 stuff.
I used to go there very occasionly in my old car and just use the normal ULP....but it was NOT a performance car lol
Guest INASNT
i know they used to use cheap malaysian import fuel when they first started, dont know about now. I filled up once with their lpg in my older car coz i was running on vapour, and as soon as i restarted my car it was farked, and drove like crap until i filled up with some other lpg.
I would never use that crap again
Guys ive worked in the fuel industry for about 3yrs and safeway fuels are EXACTLY the same as what u find at Caltex as most of them buy of the caltex newport terminal, BUT! in some cases they could get there fuel from Mobil in yarraville which would mean there premium is the same as mobil 8000, what u have todo is when your driving past your local safeway or any fuel servo that is, is stop when the fuel tanker is there refueling,and ask the driver where he loads up at,dont worry they will tell you most of the drivers are great guys. I used to get free fuel from the drivers lol and also free avgas and anything else i wanted
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
