i did a search but couldnt really find an answer
just wondering what specs my garret gt3040 is.
brought it second hand, basically new tho.
the garret plate says
700177-5014
has a .63 rear housing, external gate.
.70 comp cover
what this capable of on an rb20 with microtech, fuel system, 38mm gate, eboost2 etc
any info would be great cheers
Edited by VLT020
https://www.sau.com.au/forums/topic/113724-whats-my-gt3040-capable-of/
Probably going to be fairly laggy . GT40 large trim compressor is not the GT30 turbines best friend . I would resell it and go for less compressor next time . A GT3037 52T or propper GT3071R (cartridge no 700177-23) are much better GT30 turbine based turbos for the smallest capacity RB six .
Sorry to say it but GT3040R's are a bad mismatch of compressor to turbine especially the Garrett marketed 700177-14 cartridge because it uses a larger trim compressor than the similar 700177-9 HKS GT3040R ie 56 vs 50 trim . I was just reading today some posts from US sites about some wanting to use them in .63 turbine housing form on high performance Hondas . They are not common in the US and most people in the know can't understand why they were made in the first place , they are not optimal on anything . There's nothing they can do that the real GT30R can't do better and even it would be a bit laggy on a sedately driven street RB20 or 25 . I reckon the GT3071R modified with the 52 trim compressor like the 2871R 52T uses would be quite good . PM me if you want to know how to go about it without spending way too much .
Cheers Adrian .
I agree with Disco, as usual... the turbo wasnt too bad on my RB25... 4200rpm around 15psi.
On the RB20 it would be late 4000's even with the .63
I would also be of the inclination to sell it to someone with a bigger motor.
And get something a little smaller for the RB20... it will make it faster and a far better performer on the street and on the strip.
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
    • Glad it eventually came out Duncan!   I believe that might be 040. 044 is the inline pump, so has screw fittings in and out. 040 is more just drop it in fuel and the bottom is "open" (mesh) from my memory
    • well mate, while I hear your pain, turns out I don't feel it this time! Must have been a bastard of a job crammed into the boot The tank was very empty (probably pumped out, not dropped and drained because there were some fumes still) and in very good condition internally. I'm sure he never ran e85 in it I don't know what the hell Nissan's fuel tank engineers were thinking about their clipping system, this hanger was really hard to get moving but came out in the end All looks very good (as I'm starting to hopefully expect) and Matty was right it is an 023 (044) bosch which should be plenty for the injectors and turbo
    • Saturday 8th February 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Thursday 6th February 8pm. Supp Regs: TBC Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid  AASA General Speed licence or (Day license is $35.00 via the AASA Website) MA Licenses are no longer accepted by AASA https://aasa.com.au/ A helmet, long sleeve clothing and it is reccomended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs Above. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Entry Link >> https://www.sauvic.com.au/entry/deca/20250208 Entry List: 1. Martin Sullivan 2. Richard Hicks 3. Warren Clark 4.  5.  6.  7.  8.  9. 10.  11. 12.   13. 14 15.  16.  17.  18.  19. 20.  21.  22.  23.  24.  25. 26.    Reserve list 1.  2.
