...I have never been in the position in the car where I want to change the ratio of the plumb/atmo setting.
Hoon factor only I'd say, very Chapel Street on a Friday night...
  • Replies 48
is your car tubo charged? If so did you install a BLV "fart valve" hahah. What brand is your BOV?
Yes my car is turbo'd lol....
Standard BOV - Just with an HKS Yellow Panel Filter with no airbox lid :D Works a treat
lol, mate, my "fart back" valve is nissan brand. Its the stock BOV i am refering to
i dont know much about turbo cars. its a big switch for me from an N/A ring. so all factory turbo fitted will have a factory "fart valve" then? :( . Ehich brand will be a good buy for a "fart valve"
i get a little of both. but i'm going to replace the stock bov as they leak under descent boost with an aftermarket plumb back. i was surprised how loud the induction noise is with the fatory airbox is. all i've got is a k&n panel filter (which shouldn't make a diff anyway).
he he he if you look it's actually a mitsubushi :D
And after I turned of rice mode on the stealth, it is as quiet as a mouse, very very very quiet :P
Well imagine having that sound magnified to about 100 decibells, and that is what my stealth sounded like, but now, sweet silence, only a very small hint of whoosh :worship: scared me at first, I couldnt hear it working at all, but then after a bit I noticed it :D
  • 4 weeks later...
Bought a GFB stealth fx from LiAm on the forums, just finished installing it...in the dark...in the rain...without the propper tools...oh the pleasures of home mechanics!
Same as mine, if you want noise then two clicks from fully atmo is the furtherest I got without having stall issues, if you want no sound then it works just fine set to fully plumbback.
Well when I dissconnected the plub-back on my stock r33 bov, whenever the rpm dropped below ~2k it stalled.
When I set my stealth to anything more than about 80% atmo, I got the same issue re-appear. But I was told that if I wanted to keep it like that, all I needed was the lower rpm range remapped on the poer-fc, and that would fix the stall issue.
Instead I just set it to 100% plumb-back, works fine :angry: and no "wake the dead" PPPSSSHHHTTTT on gear change now :wub:
Hmm well apparently the car stalls. I havnt heard the BOV yet - but its stalling :D All I wanted was some noise! It has an adjustment thingo on the top, "soft" and "hard". What exactly will that change? Is the only way to stop it stalling by making it Plumb back?
I am guessing that the "Hard" and "Soft" settings are the spring setting, meaning that the harder you set the spring, the more pressure is required to make it vent.
There is a lot of stuff on SAu regarding this subject, and the only two ways of getting rid of the stall, to my knowledge, is get a dual plub-back/atmo, like the stealth which you can set to both atmo and plumb-back and set it to varying degrees, from 100% atmo, 0% plumb-back, through to 0% atmo, 100% plumb-back.
OR
Get either a plumb-back
OR
Get a atmo venting and get some sort of aftermarket ecu or piggyback ecu to tune the stall out.
:D
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
