I think they are either built fully plumb-back or fully atmo.
But you can buy adjustable ones, like the GFB Stealth, but they are not cheap, about 2yrs ago when I looked at prices a brand new stealth was worth around $500......... For something that gave you no real outcome, other than a bit of noise, it's not a very good investment, or so I thought.
I was just lucky that when I bought my stagea, it came with one.
I "tried" on my old r33 to make the stocker bov dual, but it was just too much of a problem, mainly with stalling issues, so I gave up and just went to fully plumb-back.
  • Replies 48
Ok so if I go fully plumb back it will make about the same amount fo noise as the standard one if I odnt have the airbox lid on? Plus - its legal to have an aftermarket plumb back BOV correct?
If you buy an aftermarket plumb-back bov, then it should sould exactly the same as your stocker.
Now about the legality of aftermarket BOV, here in QLD TORUM (the legistlation that QLD police are governed by) states that anything that could release petrol vapour into the engine bay is illegal, so technically a fully plumb-back bov is fine, and all types of atmo bov are illegal, because the air that is vented "could" contain petrol vapour.
If you do some searching in the qld section I posted up the whole sections of TORUM that covers the legalities of pods vs airboxes, bov's and underbody lighting.
And before you go saying that you cant find it:
|Engineering Instructions|Vehicle Accesories | |
Date Of 17/04/2 Date Of 17/04/20 No VA.06.04.0 Replaces/A
Issue: 002 Effect: 02 : 2 mends:
It has come to the notice of the Vehicle Safety and Industry Reform Section that a common modification to vehicles equipped with a turbo-charger installation is the fitting of an intercooler and a blow off valve.
Forced induction methods such as turbo-charging or super-charging have the potential to substantially increase the power and performance of a motor vehicle.
Apart from the engine itself, turbo-charging or super-charging affects four main vehicle systems. These are exhaust emission controls, vehicle noise suppression systems, braking system performance and driveline components.
Option 3 of Section LA of the Code of Practice (Light Motor Vehicles) permits the fitting of turbo-charged and super-charged engines to light motor vehicles in accordance with Schedule B of Section LA. A part of this approval requires that a “Safety Upgrade” of the vehicle is implemented in order to provide for the increase in vehicle performance.
Braking system performance and driveline components are addressed in the upgrade requirements. Additionally, the modified vehicle must continue to comply with the Australian Design Rules relating to emission controls and noise levels to which it was originally constructed.
Whilst it is recognised that a large number of the vehicles referred to in this instruction are factory fitted with a turbo-charger or super-charger installation, considerable modifications are carried out to install the intercooler, blow off valve and associated pipe work. The installation of
these components is acceptable, if fitted in accordance with good
engineering practice, i.e. it should not significantly affect the noise and emission levels of the vehicle.
Installation of blow off valves/intercoolers are regarded as accessories and do not require approval under Section LA of the Code of Practice (Light
Motor Vehicles). However, a number of vehicle owners are installing
additional “whistles” to the blow off valves (or alternative blow off valves with whistles). This procedure has attracted Queensland Police
Service attention. A number of infringement notices have been issued to
vehicle owners for, it is understood, excessive vehicle noise. Whilst the blow off valve in an unmodified state is of little concern, valves fitted with a “whistle” attachment can be quite loud.
The Transport Operations (Road Use Management – Vehicle Standards and
Safety) Regulation 1999 requires that a person must not drive a motor vehicle on a road if the vehicle’s silencing device has been modified so as to reduce, or be likely to reduce, the effectiveness of the device. As such, the silencing devices fitted to these vehicles have not been modified and the noise is not attributed to the exhaust system.
The Transport Operations (Road Use Management-Road Rules) Regulation 1999 raises issues in relation to devices fitted to motor vehicles and excessive noise emitted from motor vehicles, and is as follows:
Making unnecessary noise or smoke
S 291 (1) A person must not:
(a) start a vehicle, or drive a vehicle, in a way that makes unnecessary noise or smoke; or
(b) wilfully start a vehicle, or drive a vehicle, in a way that makes unnecessary noise or smoke.
Example of subsection (1)(a):
Driving a vehicle in a way that causes noise or smoke because of:
(a) disrepair of the vehicle; or
(b) the way the vehicle is loaded; or
© the condition, construction or adjustment of the vehicle’s engine or other equipment.
Example of subsection (1)(b):
Driving a vehicle in a way that causes noise or smoke by wilfully and unnecessarily causing the wheels of the vehicle to lose traction and spin on the road surface.
S 291 (2) A person must not drive a vehicle to which a noisy instrument
is attached or on which a noisy instrument is used.
S 291 (3) The driver of a vehicle or a passenger in or on the vehicle must
not:
(a) ring a bell or sound a horn, except a horn or similar warning device under section 224; or
(b) play or use a noisy instrument.
It would seem appropriate that the Road Rules legislation is relevant to vehicles equipped with these devices and which are modified to allow excessive noise to be emitted. The Queensland Police Service should be utilizing the Road Rules to enforce the issue, and, the owner would need to remove the device to avoid continually being issued with infringement notices.
Inspectors Action:
Transport Inspectors are advised not to issue Defect Notices solely for the reason of a vehicle being fitted with an intercooler or a blow off valve.
Any enquiries relative to this matter may be referred to the Road Use Business Management Group on telephone number (07) 3253 4851 or (07) 3253
4778. Inspectors should telephone (07) 3253 4778 or 4308 for additional
information.
Also just found this from a thread from Burkey 22...
"The problem was the tension on my spring was wound as loose at it would go. I just tightened it up abit and hey presto. Fixed."
I think the stall issue is more the fact that the stock ecu is expecting the rush of air and richens fuel ratio's accordingly, and it just puts too much fuel in and floods it I guess?
I fail to see what spring rate you set your bov to will change this, because that air is still not being fed back to the intake of the turbo.
Too tight and the bov wont open and the air will go back through your turbo, making the intake side of the turbo spin one way and then the other and so on untill the pressure is equalised. This is what is happening when you here that "cool" flutter" sound, it's actually really bad for the compressor wheel, or so I have read........?
Well at least that is what I "think" which could be totally wrong, as I am not a mechanic, nor a turbo engineer. It's just all the stuff I have read from other people posting, mainly here on SAu.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
