Hey all,
Havn't been in the import forum (or on SAU) for ages, feels good to be back.
Now that SEVS is the dominant compliance rule we use, I have come up with a question i can't find an answer for.
If I remember right, when you are going through an import broker, they arrange for the compliance shop to request the compliance plate. Then your car goes directly from the docks to compliance. Correct?
So what happens when you are importing your own SEVS car, direct from a supplier in Japan? Do you still have to have the car taken directly from the dock to compliance (is there some kind of rule?) or can you take the car home first? (Primarily to rip the aftermarket parts off yourself :( )
I Imagine this would make a big cost difference if possible....
Anyone?
Blacky
Once your car has cleared customs etc, you can pick it up from the docks.. wither get it towed or get a temp reg and drive it.
You are able to take it home, i think you have to get it complied/present it to your compliancer in 100 days from the date it arrives or something like that (maybe someone can clarify that).
I know with my compliancer..... my car arrived around chrismas so he was closing for a few weeks, if my car didnt arrive in time to get it to the shop i could take it home.
Awesome, that means that a reasonable saving can be made on modified SEVS cars - lets forget getting the workshop to remove a/m parts.
So that brings me to my next question - a compliance workshop has to apply for the SEVS import approval - is that correct? I last brought in a 92 Soarer and that was handled completely by the broker/compliancer. They apply for the approval stating that they'll be the ones complying it and then the approval is granted.Am i far off here?
Sorry if this is treaded ground but DOTARS doesn't get down to this level of detail.
Blacky
That's correct. That's why it's always good practice to get in touch with a RAWS before you purchase a car to make sure they have compliance plates available for you. Then once you've chosen a car, supply the RAWS with the VIN details and they will send off an application for import approval to DOTARS.
I picked my car up from the docks recently, however it is in need of a check up and dyno tune. I was going to get the car running in good order before taking it to the compliance workshop.
Is there any official information to state that the car does NOT have to go directly to the RAWS workshop? Is there also information that states the car can be complianced a year after arrival date?
Thanks for any advice..
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
