  • Replies 47
I got my Car Finally!!!!
1998 Toyota JZX100 CHASER!!! 1JZ VVTi Single Turbo.
Its Completely standard, 63,000 kays on the clock. Ripe for the modifying, pearl white in colour.
Ive always been a fan of the Toyotas, and I wanted something rare, so I bit the bullet and bought one finally. I am absolutely rapped with the car, its very luxurious inside and goes freakishly fast!!!
Im so eager to start modifying it, Cant wait, Hopefully within the year Ill have her running 11s!!!
Will post pics up soon!!!
Automatic. Simple fact is the price was CONSIDERABLY cheaper than a 5 speed.
Not to mention, Autos are Easy to modify and can be for this car.
MV automatics in SA - Stage 1.5 shift kit $400, 2800 stall converter - $300. Line pressure controller as well.
People are running over 350 rwhp with this setup.
If I did bust it, $2600 for a Full rebuild with upgraded clutches, kevlar belts, Stall of my choice.
Thats almost the cost of a twin plate clutch.
Check out IJZ-747 - the 10 second cressida, runs the above mentioned setup. Still on a stock Chaser IJZ bottom end too :P
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
    • I dunno what the "best" one is....but when my 040 died late last year, after about 20 years of screaming service....I put in a 255. Like any such thing, you have to finagle it a little bit - it's not a no-brain swap. But it's not hard.
