The other night if was cold as so i went to put the climate control on, turned up
the temp to 32 degress and waited for hot air to come out, waited, waited, nothing,
the only thing coming out was cold air. I was using the heater a couple of nights before
and it seemed to be working fine. Everything else work fine as far as i'm aware of,
has anyone incurred this problem before?
https://www.sau.com.au/forums/topic/113790-r32-heater-problems-climate-control/
Run a diagnostic check on the climate control system. The Workshop manual explains how to. If you dont already have it search for it and d\l it. It sounds to me that the tap that controls flow of water to the heater is not opening. It could be stuck or just plain broken.
Deren
I don't think the ambient air temp does too much.... it just tells you how high the temp is *outside* the car, and maybe does a small correction..
Proper way to test it all is.. put key in ignition position..
within 10 seconds, hold down the "off" button for 5 seconds.. will go into testing mode..
Press "up" (the arrow) 5 times i think it is (or is it 4).. this goes into the temp sensor area (it will display the temperature of each sensor in turn - there is about 4). Press AMB to view the temp each one is reading in turn. If you've got an abnormal or -30deg in any of them the sensor is bung.
There are other tests you can do when in the testing mode, but I think think the above will be most useful in this situation
There is a sensor at the front of the car (ambient read out) and there is another to the right of your ashtray behind the 4 little slits, I think, but not sure, your A/C and heater works from the temp coming from there and heats or cools accordingly. Can anyone else confirm this? :bunny:
When mine was doing this, it was the actuator arm falling off the blender motor (I think that's what it's called - that's what we called them when I worked for Ford anyway). The bit that controls whether hot or cold air came out anyway. It was stuck in the "cold" position obviously. I didn't fix it, but my mechanic had a quick look under the dash for me when I was there for something else and he fixed it in half a minute with a circlip or the like.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
