Hi
This 6 Point Roll Cage was previously in a R32 GTR.
Was only used for the race look.
Rubber a bit dirty, may need a good wash or replacing.
Asking $700.00 neg :burnout:
email me at...
[email protected]
Pics here.
https://www.sau.com.au/forums/topic/11380-fs-6-point-roll-cage-for-r32/
Hi m3m3nto, I'm thinkng along the same lines as Duncan. Generally speaking the Japanese spec cages are too small for our regs. What we need to know is the OD of the pipework and its wall thickness. This is particularly relevant to the main hoop (the one juts behind the drivers head).
Ive been told this cage was only used for the race look. Im not sure if it can been used in legal drags.
I dont know much about them as when I got the car the cage wasnt full installed, The pipe is 4cm and with rubber a good 2inches. Ive been told this the normal size.
I know the main hoop seats behind the drivers head, its seats behind the roof light, so a fair bit away from you head when seated.
I also know your back seat may need some moding to make it fit in with the cage.
I was also told if this was going to be used with drag racing that it would need to pass some test.
The cage fits to the roof but does not push the roof in and the is hardly any gap between roof and cage, fits snug.
Sorry im not the best with this if you need more info plz ask ill do my best to answer.
sorry if i didnt answer ur questions to well
OD = 5inches
The thickness is hard to say as it has no holes to let me measure it, going by the joiners I would say 0.5cm thick im only guessing tho.
Can you let me know the regulations on the cages so i can find out for myself and others.
I will email the guy I got the car off to see if he knows.
Hi M3M3NTO, from memory the CAMS regs for circuit racing is;
Material has to be cold drawn steel tube (CDS).
Tensile strength = 350 MPa min
Main hoop OD = 45 mm with 2.5mm wall thickness
or OD = 50 mm with 2.0 mm wall thickness
other bars OD = 38 mm with 2.5mm wall thickness
or OD = 40 mm with 2.0mm wall thickness
Hope that helps
Cage is....
Main Hoop OD = 40mm with 2.5mm thick
others bars are the same.
This is a Jap cage and is not made for drag racing, the bars are in good condition, rubber needs a clean and has a few marks.
Im asking $700.00 Neg, Aproved Racing Roll Cages are worth well over $1k.
Hey M3M3NTO
I think the "Kid" is trying to say maybe too expensive.... Dunno, but an approved bolt in to meet CAMS X Sydney inc GST around $AUD800.00.
The "race look" is fine and dandy, but maybe this will give you an idea of what the market can stand.
Ciao
you don't need a roll cage to pass Andra unless your running a 10 second 1/4 mile and then it can be a bolt in, if you do 9's it has to be welded in so for your average Joe this cage is fine
and I find it hard to believe that you can buy an approved bolt in for $800
  • 3 weeks later...
It will fit a GTST but u will have to mod the back seat, have to cut a little of each side, ive been told this is easy for people who deal in that stuff.
if you have more questions email me at
[email protected]
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
    • Try using Penrite 80W140, has Limslip predosed into it
