  • Replies 42
ok, thats great
one guy gets to drive home in a gtr
the other in a busted old civic
who's the real winner?
but, who really modifies cars like that for comfort....not many
just another way to look at it...
moral of the story, skylines are not invincible...
this clip is so old
the gtr isnt giving it 100%..
look at the acceleration the civic has as it goes past.
if the gtr is flooring it against a light civic that manages to accelerate that fast past the gtr.. well it would be inpossible to grab that much traction in such a light FWD car and pass a gtr like that.
and besides.. no matter how much they punch it, the other people on the road hardly seem to fall back into the distance, if it was real then you wouldnt see ppl in the backround at all
all you are seeing is a gtr gearing down and giving half throttle against a semi quick civic
this clip is so old
a civic with a k20a swap isn't slow
So one can still go round corners safly and the other cant. Cool!
That said the civic is probably giving it a good hiding. My mates fwd corolla is still being run in on 6psi and obviously less revs, stock computer shocking tune etc, and his car just EATS mine. When he gets the haltech he has installed and tuned, runs 20psi, and revs it out to 8500rpm... I highly doubt a mild to mid modded gtr will beat it (assuming he doesnt snap drive shafts, gearboxes, and somehow gets enough traction to move forwards). But his car wont go round corners, its f'ing scary now in a straight line. Moral is, you put big motors in little cars they will go very quickly, but probably wont be any good at anything else.
as usual, wanky americans building cars that dont go around corners or bends.
even if the civic bet it i would love to see both cars take it out on a race track. and to see the comments that all those people left on the video is horrible.
But untill i see an american car that can turn corners im not even gonna bother thinking that they have a decent car that can race.
There is literally no difference to strapping on a rocket to that car and lighting it while driving beside a GTR.
Edited by koleka
this has been discussed on many forums!!!
There was no race because the traffic behind is going the same speed as the skyline LOL
This thread was made by a clown that thinks that the single cam rb30's are better then a twin cam RB30.
Wouldnt take much notice of him.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
