ok i have 96 s2 r33 gtst
i got the car stock as a rock except for a pod filter...
car ran absoultally perfect...
now everything ive done is cut/bridged out that factory boost controller that gives extra boost
at 4,500rpm.so i havent turned up the boost other then that mod.it had a stock cooler and it was starting to ping etc so i put on a front mount cooler pinging went away... then probally about this time i think its my coils are breaking up and doing weird arse machine gun shots some times when im giving it all hell..now ive just put on a 3 inch turbo back exhaust,fmic,pod ,atmo bov,
im still getting this what i think is the coils playing up but also im getting some pinging as well ive always run 98 octane fuel...what should i do next..i want it back to running sweet and how it should with all these mods if i gotta spend some dollors i dont mind any help much appreciated...
also what boost should it be running now with these mods???
what next????
cheers thanks guys for th info...
https://www.sau.com.au/forums/topic/113822-car-mods-and-problems-peoples-views/
what next????
Best to change the coils this might smoothen things up as well as check or afr's might help in the pinging area
had the exact same problem!
check plugs, coils etc. if problem still persists, see your local dyno tuner. That was my scenario....did some runs, ran a fuel flow test etc. I had wrong sparks in, timing was off and discovered the pump was lazy. Replaced sparks and under tuned the car to be safe until I go back and install a walbro. currently organising an arc sidemount to replace the standard one before I go back for the walbro pump and tune. :)
on another topic, I first witnessed the change in skylines with different climates...goes so much harder in the cold :( turbos and husky's have much in common.
Edited by Staunch
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
