hey guys i've done the searches and still don't know what s going on. i just got my turbo hi-flowed and the boost rises freely. as soon as i put the foot down it flies past 1 bar. i took the bleed valve out and left it as stock setup and it goes to .8 bar for a split second and as the revs climb so does boost to 1 bar. i've checked lines i've made sure it fitted right. if i connect the wastegate to the bleed valve and the hose off the cooler to the bleed valve and block off the third line, winded up the boost the boost just climbs like it was on stock setup, as if it wasn't there. if i hook up the wastegate to the bleed valve and T piece the hose from the cooler and the third line then connect it up to the bleed valve it just flies to 1 bar and over. does anyone know what to do i want it to be set at 12 psi and hold. please need help
yeah exactly as stated by craved i did that. the boost goes to .8 bar then as the revs climb so does the boost to 1 bar. now whether i set the bleed valve to 12 psi or close it off it does the same thing. it goes to .8 bar then climbs with the revs to 1 bar
only other thing is that the wastegate cannot allow enough gas out to allow the lower boost setting
or
the wasegate is sticking and not opening fully to allow that boost reading.
what sort of supporting mods do you have?
and does it hold at 14.7 psi once it gets there?
okay i've got a intercooler, full exhaust and now the turbo....still working on getting a computer.
last night i changed the wastegate to my old one and now the boost goes to .5 bar and then slowly creeps to 1 bar with the revs.
the boost doesn't just sit at 14.7 psi it goes to whatever...it just free boost...it once when to 1.5 bar
hey thanks for your info craved but still doin my head in
you think its a good idea to change the wastegate to something else
well the way i've hooked it up is from the
1. cooler hose->bleed valve->wastegate = it goes to .5 bar then when the revs climb so does the boost to 1 bar
2. cooler hose T piece with the other vacuum line->bleed valve->wastegate = i get free boost
with option 1 i turn winded up the bleed valve and it doesn't do anything it's like its not even there. it just does what is above at option 1. its the same for option 2 its as if the bleed valve is not even there
Have you try just running wastegate pressure? As in cooler hose to wastegate. If so what happens then??
Try wiring your wastegate wide open. Or disconect the actuator from the wastegate flap so it's wide open. (internal gate right?) Then go for a drive. See what boost you get. If you still get a bar with the wastge wide open, then your waste gate isn't big enough. I had a little problem like this when I fitted a dump pipe and an air pod filter. My guess is the extra breathability of the combined dump and air pod meant that either the wastegate was too small, or the actuator wasn't opening the wastegate enough when it was full extended.
Fixed it with a Jaycar Independant electronic boost controller.
My max PSI was about 9, so I tuned the IEBC to run 9psi the whole way through the rev range for a flat boost curve. You would have to do the same for 14.7psi
I also found that after fitting another pod filter that was more restrictive, boost would start to creep up and then fall off at the top of the range.
hope this helps...
hey thanks for the reply guys, craved i've changed all the hoses before i posted it and it doesnt change same shit. i'll try what chrisso said and disconnect the actuator thanks for the info mate. kyro if you could let me know about your mate with the sr much appreciated. the hiflow was done at JPC in thomastown in melbourne
    • As strange as this sounds (as they are fixed back), my Bride Xero CS seats are the most comfortable seats I've used.  I vote go genuine.  The only downside I've found is on very long drives, you can't reposition your body while driving. So even though its comfy, being locked in the same position eventually becomes uncomfortable. I find myself stopping every 3 or so hours to stretch my legs on long drives.
    • You don't have to be bored driving a Camry. Not based on the way that a couple of f**king Ubereats/Didi/othersortofmethaddlednightshiftattheservicestationrecentimmmigrants were piloting them on the way to work this morning. f**k me dead!
    • FWIW, the Bride reps are really nice to sit in. The only complaint I have, other than the tear in my bolster, is that the velcro used to hold the backrest cushion in place, up under the headrest, is a little obvious and intrusive and could probably be done better. I don't know if that is a "feature" on the genuine ones also though. I haven't looked at a genuine one like the ones I have, only some of the older models. The other thing is, even though I bought the CF ones, I think the CF is really just decorative, over the top of the same FG as the normal seats. And so they really aren't light. Between the solidly built CF/FG seat, the steel frame in the recliner mechanism, and the solid-arse seat rail, they are probably heavier than even the stock seat. They are a serious lift to get in and out of the car.
    • Yes, and so the barest minimum power target is the one that makes the most sense. Massive power is fun, but you can only use it for 1.5s at a time, and only every now and then. Medium power levels allow you to enjoy the car far more often and for longer. 500 engine HP is just below 300 rwkW which is about the maximum that is sensible for any street car really. And for a 2.6L six, it will still leave you with a decent boost response and some sort of linearity of power delivery. As you get up towards 400rwkW the onset of power tends to be increasingly like a cliff and you need drag radials to keep the ground in proper contact with the car, and.... it's just not a car for driving around any more.
    • I already reached that conclusion myself after reading up a whole bunch and watching various videos from multiple sources. Don't know yet how I'd best manage that with the least amount of headache. Probably pulling the sump and just welding on a AN10 adapter or something. I also think it's healthy to take most opinions with a grain of salt, because experiences differ wildly and especially Aussies - when talking about RBs - don't know a world below 600whp drag builds. Personally I doubt I will ever take my R33 racing, so it's going to be a street car with the occasional spirited drive. Hence why I am (so far) under the impression that I'm going to be fine with a stock-ish engine for a while.
