hey guys i've done the searches and still don't know what s going on. i just got my turbo hi-flowed and the boost rises freely. as soon as i put the foot down it flies past 1 bar. i took the bleed valve out and left it as stock setup and it goes to .8 bar for a split second and as the revs climb so does boost to 1 bar. i've checked lines i've made sure it fitted right. if i connect the wastegate to the bleed valve and the hose off the cooler to the bleed valve and block off the third line, winded up the boost the boost just climbs like it was on stock setup, as if it wasn't there. if i hook up the wastegate to the bleed valve and T piece the hose from the cooler and the third line then connect it up to the bleed valve it just flies to 1 bar and over. does anyone know what to do i want it to be set at 12 psi and hold. please need help
yeah exactly as stated by craved i did that. the boost goes to .8 bar then as the revs climb so does the boost to 1 bar. now whether i set the bleed valve to 12 psi or close it off it does the same thing. it goes to .8 bar then climbs with the revs to 1 bar
only other thing is that the wastegate cannot allow enough gas out to allow the lower boost setting
or
the wasegate is sticking and not opening fully to allow that boost reading.
what sort of supporting mods do you have?
and does it hold at 14.7 psi once it gets there?
okay i've got a intercooler, full exhaust and now the turbo....still working on getting a computer.
last night i changed the wastegate to my old one and now the boost goes to .5 bar and then slowly creeps to 1 bar with the revs.
the boost doesn't just sit at 14.7 psi it goes to whatever...it just free boost...it once when to 1.5 bar
hey thanks for your info craved but still doin my head in
you think its a good idea to change the wastegate to something else
well the way i've hooked it up is from the
1. cooler hose->bleed valve->wastegate = it goes to .5 bar then when the revs climb so does the boost to 1 bar
2. cooler hose T piece with the other vacuum line->bleed valve->wastegate = i get free boost
with option 1 i turn winded up the bleed valve and it doesn't do anything it's like its not even there. it just does what is above at option 1. its the same for option 2 its as if the bleed valve is not even there
Have you try just running wastegate pressure? As in cooler hose to wastegate. If so what happens then??
Try wiring your wastegate wide open. Or disconect the actuator from the wastegate flap so it's wide open. (internal gate right?) Then go for a drive. See what boost you get. If you still get a bar with the wastge wide open, then your waste gate isn't big enough. I had a little problem like this when I fitted a dump pipe and an air pod filter. My guess is the extra breathability of the combined dump and air pod meant that either the wastegate was too small, or the actuator wasn't opening the wastegate enough when it was full extended.
Fixed it with a Jaycar Independant electronic boost controller.
My max PSI was about 9, so I tuned the IEBC to run 9psi the whole way through the rev range for a flat boost curve. You would have to do the same for 14.7psi
I also found that after fitting another pod filter that was more restrictive, boost would start to creep up and then fall off at the top of the range.
hope this helps...
hey thanks for the reply guys, craved i've changed all the hoses before i posted it and it doesnt change same shit. i'll try what chrisso said and disconnect the actuator thanks for the info mate. kyro if you could let me know about your mate with the sr much appreciated. the hiflow was done at JPC in thomastown in melbourne
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
