A cryo'd std block will do fine...much cheaper too
Nismo don't seem to think so. Back in the day before 24U blocks, NISMO couldn't get 05U blocks to last at more than 450PS for endurance use.
Also, when 24U blocks were available, there was only about 10,000JPY between an 05U and a 24U.
https://www.sau.com.au/forums/topic/113886-gtr-block/#findComment-2100039
Did Nismo cryo and de-burr their blocks??
Mark Jacobsen, Theo Wollett, Croydon's and Myself seem to have had great service from 05U blocks.
Extensive abuse has proven my theory in "real world"....i think you should go back to your books boy!
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/113886-gtr-block/#findComment-2100048
Real world testing has proven my theory in real world....i think you should go back to your books boy!
NISMO did 'prepare' their blocks, not too sure what that meant, but I'd imagine it would be heat tempering them rather than freezing them. I'm not convinced that cryo treating a block would stop it cracking.
As for deburing...not sure whether they did or not, but my block was deburred from factory. But in any case, Rb26 blocks usually crack between 3 and 4 on the water jacket...good luck deburring it in there.
Notice I said endurance use...not a 10-15 second squirt. A top fuel engine pulls 6000bhp, but lets see what happens if you try to run it for more than 20 seconds.
And NISMO did real world testing...and I bet they have built (and broken) more RB26's over the past 17 years than any other organisation on earth.
https://www.sau.com.au/forums/topic/113886-gtr-block/#findComment-2100067
Who "endurance races" their Skyline anyway?? The track days you would be lucky to get 5 "hot" laps in...and the State champs guy's would be lucky to see a dozen. Like i said this is the real world we are discussing not something you have read.
Suppose we better wait and see what sort of monster acxacx is building before making judgement on what he really "needs"....I see Buster has a suitable block up for grabs for good $$...
https://www.sau.com.au/forums/topic/113886-gtr-block/#findComment-2100076
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
    • Potentially some interesting data for some of you here; Hank Iroz from Iroz Motorsport testing a new Xona Rotor 5964S on a Audi RS3 2.5L DAZA motor. https://facebook.com/share/p/14EU18MyDqZ/ Cliff Notes: Turbo has the new Xona XRE compressor aero with an X4C compressor cover, reportedly 0.64 rear housing. 900whp (670kw) @ 37psi, 170k shaft speed, motor is making 2bar (29psi) boost by roughly 3800rpm, 500lbft (670nm) torque by 3500rpm. They overlaid a stock RS3 on USA 91 fuel (red), and a "Stage 2" RS3 on E85 (yellow), and this 5964S (blue) - the 5964S isn't losing any ground to either. Apparently out-flowing their prior tests with a Xona 8264S (green), and this 5964S (white) also has a smaller A/R than that did.
