A cryo'd std block will do fine...much cheaper too
Nismo don't seem to think so. Back in the day before 24U blocks, NISMO couldn't get 05U blocks to last at more than 450PS for endurance use.
Also, when 24U blocks were available, there was only about 10,000JPY between an 05U and a 24U.
https://www.sau.com.au/forums/topic/113886-gtr-block/#findComment-2100039
Did Nismo cryo and de-burr their blocks??
Mark Jacobsen, Theo Wollett, Croydon's and Myself seem to have had great service from 05U blocks.
Extensive abuse has proven my theory in "real world"....i think you should go back to your books boy!
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/113886-gtr-block/#findComment-2100048
Real world testing has proven my theory in real world....i think you should go back to your books boy!
NISMO did 'prepare' their blocks, not too sure what that meant, but I'd imagine it would be heat tempering them rather than freezing them. I'm not convinced that cryo treating a block would stop it cracking.
As for deburing...not sure whether they did or not, but my block was deburred from factory. But in any case, Rb26 blocks usually crack between 3 and 4 on the water jacket...good luck deburring it in there.
Notice I said endurance use...not a 10-15 second squirt. A top fuel engine pulls 6000bhp, but lets see what happens if you try to run it for more than 20 seconds.
And NISMO did real world testing...and I bet they have built (and broken) more RB26's over the past 17 years than any other organisation on earth.
https://www.sau.com.au/forums/topic/113886-gtr-block/#findComment-2100067
Who "endurance races" their Skyline anyway?? The track days you would be lucky to get 5 "hot" laps in...and the State champs guy's would be lucky to see a dozen. Like i said this is the real world we are discussing not something you have read.
Suppose we better wait and see what sort of monster acxacx is building before making judgement on what he really "needs"....I see Buster has a suitable block up for grabs for good $$...
https://www.sau.com.au/forums/topic/113886-gtr-block/#findComment-2100076
    • Um.... This is not easy. I will have a fiddle with it, but make no promises. I think, given the explicit resistances vs temperature, and your ECU measured voltages, it should be possible to match them up. I will do that by assuming a 5V supply from ECU to sensor, find out how much current would have to flow to produce that voltage, then use that current as a .... nah f**k. That won't work. The supply voltage is fixed, but there's nothing to say that the ECU regulates the current too. Um... I dunno. I guess there's a voltage divider setup in the ECU. As in, there's another resistance between the ECU's sense terminal and ground. That way, as the sensor resistance changes, that's how they get a floating voltage that varies with the temperature, without having to control the current. Give me a minute or 3.
    • *that* is a question for chatgpt (or someone that understands maths....but I'd try chatty). Drop them the table and ask for the formula
    • Alright. Exhaust has been looked at, and booked in 'soon'. I'm not 100% convinced it's going to be as good as possible but I'm going to go with it anyway. If I get a reasonable thing that works for 10 years I mean that's twice as long as I've lived with the current one. I have a more pressing issue. I have fixed my MPVI3 (by buying a new one). Excellently, one can wire in analog 0-5v inputs to the ECU itself. I had wideband already via Serial so I also wired it in via the direct input. The idea being I can use the standalone logging without a laptop and have Wideband data in it. The other wire I thought I'd use oil temp. This is where I've gone crazy. HPTuners requires you to implement a formula so you know how much volts = how much temp. This seems relatively simple to me. However I cannot find the scale for this anywhere on the internet, nor decipher how to figure it out without removing the sensor from the car. All I know is that voltage actually goes up as temperature goes down. I am using the actual gauge, so I can see what the temp is. The signal wire has been branched off into the MPVI3. EXAMPLE: 2.68v = 58C 2.7 = 57C 2.74v = 56C 2.8V = 54C 3.06V = 49C 3.18V = 47C 3.37V = 43C I think the gauge is 50-150C. It may be more. It may be less, because I can't find it for the love of f**k. It appears all the information about the gauges I have has been scoured from the internet, but the sender is VDO 320.021 I believe the resistance chart is this How the f**k do I convert this to a voltage? Once I have a voltage... I then have to perform this transform of said voltage to show it in the scanner: https://www.hptuners.com/help/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm @GTSBoy you're probably my only hope here TEST YOUR MIGHT
    • Here’s the updated and installed muse replica nismo ones … very happy with the outcome. Eventhough I painted my whole rear end due to my rich idle lol.
    • Hmm. I had a good look (w/o searching, because I'm not logging in) and couldn't see it either. I distinctly recall the thread, not many weeks ago. It must have been removed or perhaps put into the back section. If it was in Off Topic you should at least have been able to search it up. So if I'm not hallucinating, it is fairly decently removed.
