Well its up to you. You can go with your standard block, but I dont like that idea. Nissan ran endurance tests on 05u and 24u blocks. They found 9/10 standard blocks cracked after 2000kms of testing on 05u blocks. 0/10 24u n1 blocks cracked after this endurance testing.
I dont care what you say, but have a look at this. It should convince you otherwise.
A comparison with a gt and a 05u block. I know I certainly would not go for an 05u if i was running 86.5 or 87mm bore, or even running big power through it.
And 'Doughboy's' block is gone, and will be in my capable hands on thursday :spank:
Just a bit more
Consider running an 86.5mm bore. That gives you just under 5mm wall thickness on either side of the piston, with an n1 block. Although I dont know the wall thickness of a standard block, based on the pictures, they look to be about half that of the gt block. Assuming that, you only have a 3mm wall thickness with a 86 mm bore and less than that if you go 86.5mm. Carrying around 100hp per cylinder, i wouldnt trust it to last terribly long with less than 3mm of wall thickness at those sorts of cylinder pressures.
Food for thought I suppose. Does anyone know the standard block wall thickness ???
Just a bit more
Another interesting point is that Nissan had a recall on 05U blocks due to them leaking coolant between 3&4 above the oil boss.
But every casting is different, so I guess with blocks, it is the luck of the draw.
But, ask Darren from Just Jap how long an 05U block lasts him in his Targa car, and he wouldn't be running more than about 500hp.
Tommy amd Mik you both been reading to many books, just listen to the pro above , dont worry about Nismo, how would they know what they are doing ?
Well i dont know about you Tommy but i know Mik hasn'tand still doesn't read or buy any books!!
And 'Doughboy's' block is gone, and will be in my capable hands on thursday :P
but that pic says that n1 block is 96 mm (which with a 87mm bore leave a cylinger wall thickness of 4.5mm) and GT is 98mm (which with same bore leaves 5.5mm). what is the thickness of the standard 32? and if the GT one is superior why are you getting the N1 block? i thought you were going crate engine?
Hahaha...the dynamic duo are at it again.
Never doubted the N1 product or even the GT500 block....point was....is it needed for his application....and from his response....i think not.
acxacx i hope this information provided has been useful in your decision...the 05U product is not as bad as some people may lead you to believe....yes the N1 item is better....but in most applications its overkill.
Ok well lets see
Ive been trying to source an n1 block for the last month. In Australia, nissan parramatta has 1 block. they want 3700 for it. TRADE PRICE
Justjap dont have stock. Give them a call. Hi octane have no stock. Sorry I believe they have a gt block for 6k. no thanks
I called my contacts in japan. Nissan japan has NO STOCK. Go on. Give them a call. You will find there are none. Nissan has no plans to recommit to further production. There are some specialised workshops in japan that have a small amount of inventory left, but they sell these as parts of complete motors. You may be able to find a 2nd hand on yahoo japan, or at a 2nd hand parts shop. My japanese parts broker has quoted me 200,000 yen plus shipping for a brand new n1 and this is after extensive searching and there is apparently a 4 month wait invovled ? So they definitely are around, if you have the money and time and patience.
At the end of the day, Paul believes you dont need one, so dont get one. When you start losing coolant and start to wonder why, come back to this thread. Im not saying it will happen or it wont happen, but im not a mechanic. When I do my build, I dont want to pull out my motor again for another 100,000 kms. Paul on the other hand can pull out his engine, refit a new block with pistons rods and crank. New bearings, new rings, new headgasket and new bolts. Oh and the pleasure of running it in again. I dont have the mechanical ability to do that. NOR do i want to be spending any more money after. Do it once, do it right.
Believe what you want to believe. Pauls running 460awkw through his block and its fine. You should listen to him
Just trying to help the guy make an informed decision....not trying to sway him either way.
Chicken little said the sky would fall too.....
The way you guys are going on you'd swear everybody without an N1 or GT500 block has a timebomb under their hood.
BTW..... the best AWKW figure we have seen is only 443.
Good luck with your build
Edited by DiRTgarage
    • Try looking at Eibacb/H&R springs Thats what Gary sourced for mine.
    • Hey y'all! I'm curious about how y'all go about widebodying your cars. I noticed that when running a square setup, my front wheels are a bit more tucked in than my rear wheels. Not by much, maybe 5-10mm. This leads me to wonder - when I widebody, should I use narrower front flares and wider rear flares? I found a set of 40mm rear flares that I really like, and was thinking of pairing them with some 18mm front flares, but I don't want the car to look strange. How have others done this? Note, I'm in a sedan. Thanks!
    • And if it was anything other than an auto tranny part, it might be a problem. But seeing as all auto trannies belong in the recycling bin, it's fine.
    • I have an R32 Fenix rad. It is good.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
