Well its up to you. You can go with your standard block, but I dont like that idea. Nissan ran endurance tests on 05u and 24u blocks. They found 9/10 standard blocks cracked after 2000kms of testing on 05u blocks. 0/10 24u n1 blocks cracked after this endurance testing.
I dont care what you say, but have a look at this. It should convince you otherwise.
A comparison with a gt and a 05u block. I know I certainly would not go for an 05u if i was running 86.5 or 87mm bore, or even running big power through it.
And 'Doughboy's' block is gone, and will be in my capable hands on thursday :spank:
Just a bit more
Consider running an 86.5mm bore. That gives you just under 5mm wall thickness on either side of the piston, with an n1 block. Although I dont know the wall thickness of a standard block, based on the pictures, they look to be about half that of the gt block. Assuming that, you only have a 3mm wall thickness with a 86 mm bore and less than that if you go 86.5mm. Carrying around 100hp per cylinder, i wouldnt trust it to last terribly long with less than 3mm of wall thickness at those sorts of cylinder pressures.
Food for thought I suppose. Does anyone know the standard block wall thickness ???
Just a bit more
Another interesting point is that Nissan had a recall on 05U blocks due to them leaking coolant between 3&4 above the oil boss.
But every casting is different, so I guess with blocks, it is the luck of the draw.
But, ask Darren from Just Jap how long an 05U block lasts him in his Targa car, and he wouldn't be running more than about 500hp.
Tommy amd Mik you both been reading to many books, just listen to the pro above , dont worry about Nismo, how would they know what they are doing ?
Well i dont know about you Tommy but i know Mik hasn'tand still doesn't read or buy any books!!
And 'Doughboy's' block is gone, and will be in my capable hands on thursday :P
but that pic says that n1 block is 96 mm (which with a 87mm bore leave a cylinger wall thickness of 4.5mm) and GT is 98mm (which with same bore leaves 5.5mm). what is the thickness of the standard 32? and if the GT one is superior why are you getting the N1 block? i thought you were going crate engine?
Hahaha...the dynamic duo are at it again.
Never doubted the N1 product or even the GT500 block....point was....is it needed for his application....and from his response....i think not.
acxacx i hope this information provided has been useful in your decision...the 05U product is not as bad as some people may lead you to believe....yes the N1 item is better....but in most applications its overkill.
Ok well lets see
Ive been trying to source an n1 block for the last month. In Australia, nissan parramatta has 1 block. they want 3700 for it. TRADE PRICE
Justjap dont have stock. Give them a call. Hi octane have no stock. Sorry I believe they have a gt block for 6k. no thanks
I called my contacts in japan. Nissan japan has NO STOCK. Go on. Give them a call. You will find there are none. Nissan has no plans to recommit to further production. There are some specialised workshops in japan that have a small amount of inventory left, but they sell these as parts of complete motors. You may be able to find a 2nd hand on yahoo japan, or at a 2nd hand parts shop. My japanese parts broker has quoted me 200,000 yen plus shipping for a brand new n1 and this is after extensive searching and there is apparently a 4 month wait invovled ? So they definitely are around, if you have the money and time and patience.
At the end of the day, Paul believes you dont need one, so dont get one. When you start losing coolant and start to wonder why, come back to this thread. Im not saying it will happen or it wont happen, but im not a mechanic. When I do my build, I dont want to pull out my motor again for another 100,000 kms. Paul on the other hand can pull out his engine, refit a new block with pistons rods and crank. New bearings, new rings, new headgasket and new bolts. Oh and the pleasure of running it in again. I dont have the mechanical ability to do that. NOR do i want to be spending any more money after. Do it once, do it right.
Believe what you want to believe. Pauls running 460awkw through his block and its fine. You should listen to him
Just trying to help the guy make an informed decision....not trying to sway him either way.
Chicken little said the sky would fall too.....
The way you guys are going on you'd swear everybody without an N1 or GT500 block has a timebomb under their hood.
BTW..... the best AWKW figure we have seen is only 443.
Good luck with your build
Edited by DiRTgarage
    • You have found the problem. The wire from the switch to the HB is shorted to earth. Now you have to physically find it and replace it. It won't be the switch, although following the steps above (and yes, where you ask, that is the light switch on the RHS of the binnacle) will rule it out for sure. Or not, if perhaps the switch has melted. But there's no route to earth inside the switch, so I can't see how it would.
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
