Well its up to you. You can go with your standard block, but I dont like that idea. Nissan ran endurance tests on 05u and 24u blocks. They found 9/10 standard blocks cracked after 2000kms of testing on 05u blocks. 0/10 24u n1 blocks cracked after this endurance testing.
I dont care what you say, but have a look at this. It should convince you otherwise.
A comparison with a gt and a 05u block. I know I certainly would not go for an 05u if i was running 86.5 or 87mm bore, or even running big power through it.
And 'Doughboy's' block is gone, and will be in my capable hands on thursday :spank:
Just a bit more
Consider running an 86.5mm bore. That gives you just under 5mm wall thickness on either side of the piston, with an n1 block. Although I dont know the wall thickness of a standard block, based on the pictures, they look to be about half that of the gt block. Assuming that, you only have a 3mm wall thickness with a 86 mm bore and less than that if you go 86.5mm. Carrying around 100hp per cylinder, i wouldnt trust it to last terribly long with less than 3mm of wall thickness at those sorts of cylinder pressures.
Food for thought I suppose. Does anyone know the standard block wall thickness ???
Just a bit more
Another interesting point is that Nissan had a recall on 05U blocks due to them leaking coolant between 3&4 above the oil boss.
But every casting is different, so I guess with blocks, it is the luck of the draw.
But, ask Darren from Just Jap how long an 05U block lasts him in his Targa car, and he wouldn't be running more than about 500hp.
Tommy amd Mik you both been reading to many books, just listen to the pro above , dont worry about Nismo, how would they know what they are doing ?
Well i dont know about you Tommy but i know Mik hasn'tand still doesn't read or buy any books!!
And 'Doughboy's' block is gone, and will be in my capable hands on thursday :P
but that pic says that n1 block is 96 mm (which with a 87mm bore leave a cylinger wall thickness of 4.5mm) and GT is 98mm (which with same bore leaves 5.5mm). what is the thickness of the standard 32? and if the GT one is superior why are you getting the N1 block? i thought you were going crate engine?
Hahaha...the dynamic duo are at it again.
Never doubted the N1 product or even the GT500 block....point was....is it needed for his application....and from his response....i think not.
acxacx i hope this information provided has been useful in your decision...the 05U product is not as bad as some people may lead you to believe....yes the N1 item is better....but in most applications its overkill.
Ok well lets see
Ive been trying to source an n1 block for the last month. In Australia, nissan parramatta has 1 block. they want 3700 for it. TRADE PRICE
Justjap dont have stock. Give them a call. Hi octane have no stock. Sorry I believe they have a gt block for 6k. no thanks
I called my contacts in japan. Nissan japan has NO STOCK. Go on. Give them a call. You will find there are none. Nissan has no plans to recommit to further production. There are some specialised workshops in japan that have a small amount of inventory left, but they sell these as parts of complete motors. You may be able to find a 2nd hand on yahoo japan, or at a 2nd hand parts shop. My japanese parts broker has quoted me 200,000 yen plus shipping for a brand new n1 and this is after extensive searching and there is apparently a 4 month wait invovled ? So they definitely are around, if you have the money and time and patience.
At the end of the day, Paul believes you dont need one, so dont get one. When you start losing coolant and start to wonder why, come back to this thread. Im not saying it will happen or it wont happen, but im not a mechanic. When I do my build, I dont want to pull out my motor again for another 100,000 kms. Paul on the other hand can pull out his engine, refit a new block with pistons rods and crank. New bearings, new rings, new headgasket and new bolts. Oh and the pleasure of running it in again. I dont have the mechanical ability to do that. NOR do i want to be spending any more money after. Do it once, do it right.
Believe what you want to believe. Pauls running 460awkw through his block and its fine. You should listen to him
Just trying to help the guy make an informed decision....not trying to sway him either way.
Chicken little said the sky would fall too.....
The way you guys are going on you'd swear everybody without an N1 or GT500 block has a timebomb under their hood.
BTW..... the best AWKW figure we have seen is only 443.
Good luck with your build
Edited by DiRTgarage
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
