hi everyone,
iv'e just removed my engine from the skyline.
i was thinking while the gearbox is out, i might aswell change the flywheel to something lighter.
i haven't physically checked the clutch & pressure plate, but the car drives perfectly.
my question is...
If i change the flywheel only, will i run into any problems?
Is changing the flywheel something u would only do if the clutch needed changing?
any help will be appreciated
vince
Also i started trying to use the search tool, but iv'e spent 2 hours reading through posts with no luck.
Hey mate, I don't think you should really run into any major problems if you change the flywheel and not the clutch. Just so long as there is plenty of meat on the clutch as i'm sure there will be some bedding in process to occur, probably for the first coupla hundred kays while the face of the flywheel is well, bedding in with the clutch.
By the very nature of this process there will be some irregularities that would have built up over time on the old flywheel that were matched on clutch. Moving to a new faced flywheel should do the same thing to a point, essentially wearing down the 'high points'.
Out of curiosity what kind of clutch is it (organi etc?), and how long have you had it in?
It might save a whole lot of stress now to get a new clutch in while the engine's out. While you're at it, if it hasn't been done, change the rear main, spignot bearing etc.
Another option if you are concerned about the clutches life span and you want to go to a lightweight flywheel is a twin or triple plate clutch. Essentially the flywheel is built into these kits (and is lightweight), and it is reflected in the price. The upside is better driveability, more power handling than stock. The downsides are more chattering in neutral and the higher initial outlay. Although when you combine the cost of a new heavy duty clutch kit and a lightweight flywheel, the price difference isn't all that much!
Probably the best person to talk to on here who should really be able to help you out is 3lit3 32. He works at ABS and does some very good deals for SAU people in Brisbane. He's very helpful when it comes to all things driveline.
Hope rant helps.
-Insu
You should be aware from the current exercise of the time and effort involved in accessing the clutch. That equates to $$$$.
I would suggest that while it's all apart, take the opportunity to replace (upgrade?) the clutch. It might cost a couple 100 now, but it will cost a lot more when you really need to replace the clutch.
If you already have the uprated pressure plate i'd really consider either a re-puk of the friction plate if it's a puk type clutch obviously or a replacement full face plate.
It's easy to do while it's all apart
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
