Hey guys,
I just wanna know how much u guys r spendin on fuel a week, giving it a bit and not giving it a bit, like i wanna compare a relativley stock gtr to a mild modded gtst, pleave forgive me if this has been covered and re-direct me to the right thread.
Cheers
John
https://www.sau.com.au/forums/topic/113900-fuel-consumption-gtr-vs-gts-t/
I use BP Ultimate in my GT-R. If you drive like an absolute granma and pretty much never send the boost gauge too far above the zero mark/ always change up at 3000rpm or so, then you can get 600-650km out of a tank if you do mostly constant driving (till the fuel light comes on). But that's pretty painful.
I managed 400kms on 3/4 of a tank recently with a mix of light fanging/cruising/highway and city/town driving. Also, my car uses a plug'n'play Microtech LTX12 computer, which uses the Throttle Vs Map fuelling control, which is supposed to be more efficient than using the AFM's (A number of people have commented that they get better fuel economy when they set their Power FCs up with the D-Jetro option [which makes it work like the Microtech])
How bad can it get?- My car makes 260rwkW with stock turbs, and I once used 3/4 of a tank to travel 160km, which consisted of heaps and heaps of full-throttle thrashing.
What price fun?
cool thanx for the info from all u guys out there, still deciding on weather to buy the gtr tho has anyone see the black 32 with the white mags at autostyle? what do u reckon of that. sorry to go off topic
GTR - can get as low as 200k's to a tank
Depends how you drive it
I meant bouncing it off the rev limiter
hey N1GTR,
but if u drive smoothly ud get way more than 200 ay
Of course it will be better on fuel without full boost, they can be quite good on fuel if you dont drive it on boost - but really, why else would you drive a GTR?
isn't this what he is implying?
I get about 450kms to a tank during the working week and weekend fun is literally half that :laugh:
Yes, thats what i was implying
Hope this helps :(
Feel free to PM me if you want to know more
better fuel economy with a map sensor system is load of poo, it wont matter. engine load is engine load. its just tuned differently.
i get 400k's to a full tank on city
and 600ks on highway
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
