Killer T,
First Line: 100/100/100/101/102/103/101/100/100/101/103/101/100/115/119/125/125/125/125/125
Second line is the same
third line:
100/100/99/101/97/102/100/.....there after as for line one and two.
A bit different from yours, I am running a Z32 AFM as well, so that may be influencing things. My AF ratios are a pretty constant 12.3:1 and I get no detonation even on hot days running 0.85bar boost.
  • 1 month later...
sorry late reply,
but did u end up getting it fixed?...
i have the same problem
funny thing is that it goes to normal after a 30min drive but sometime it doesnt, its so unpredictable
most of the time i feel like pulling my hair out & packing the power fc away & put back in the factory ecu & some other days i dont take notice of it at all.
it normally goes 1200rpm then drops back to 750rpm then rise again.
Some people has said it was the wrong selection of your AFM, my settings on afm meters are correct so i dont know.
If you have solved the mysterious idle problem please let me know ;)
ive known a few powerFC's to hunt at idle. mine is good with a Z32 AFM.
the fuel maps should be very close to the 100 setting for a car with stock cams. the higher the number the richer so if your car is cammed then add a bit more fuel to stabilise it.
check the temperature compensation. sometimes if the idle is rich and the temp compensation kicks in the idle deteriorates.
check the temperature the engine is running at. (see above)
rb25 should idle with 15 degrees timing. if i recolect. check this too in the ignition map.
check what the timing is with a light. if the reading on the crankisnt the one on the map then you should correct this.
check the fuel cut recovery points and idle speed.
pawL.
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
