Fitting 6x9s An Ecr33
oil pressure sensor sits on the filter block, i believe after the filter but i may be wrong about that.
Yes and no. My second sentence is trolling but being that you're also from North America, I was really hoping you would catch onto my ICP reference. Then again, I'm probably one of the only idiots who listened to ICP when I was younger. Jokes aside, if the magnet went in through the drain hole, then I'm sure you can get it out by there. Try some of the options the others have listed. -
Just get the magnet out... I can think of 37 different options to get it out without removing the pan. 4-5x of those options are already mentioned here. I personally would drill a larger hole in the pan, pull the magnet out and then block the hole with another magnet. Then reuse another magnetic oil plug. The more magnets the better.
