Hi ppls,
I'm looking in to diff ratio's and diff swaps for my R32 as the std VLSD open wheels and the ratio is too low (numberically high) for the RB30.
I've been looking at a 3.69:1 ratio as for the way I drive it appears the turbo will be spooling perfectly as I leave corners etc. + the added advantage of improved economy with PULP soon to hit $1.50 per litre. :D
I've spoken to a few diff rebuilders and to simply swap a pinion and ring gear they want around $300-$400 + the gears which I can pick one up for $150, then I need to drop a decent center in it, possibly a GTR mech center for $550. So its going to work out fairly expensive.. $1100 or there abouts for a decent center and ratio change.
I then came across one diff rebuilder that said why not look at dropping a early 90's Z32 TT R230 in to it. They run the ratio I am after and with a few little modifications they bolt up.
'Apparently' swap the input flange and solid mount the front rubber bushes, the early Z32 R230's run the 5bolt half shafts. It sounds too easy as I'm sure the R230 I had a quick look at looked wider than my R200.
Has any one had any experience with the R230's or has access to one that can check out the rear cover plate?
https://www.sau.com.au/forums/topic/113968-r230-z32-tt-diff-in-to-r32/
Hi ppls,
hey buddy, a friend of mine bought a z32 diif to put in his cefiro (same subframe as r32) apart from the half shafts being 6 bolt, and the input being different also, there is know way it will fit in your subframe, its just too wide, aand you cant swap backing plates with a r200 (comlpetely differnet).
The only option, which he is looking into, is getting a z32 subframe. looks like it may bolt up. As for early z32's haveing 5 bolt driveshafts, my g'f has a 1889 tt zed and its 6 bolt.
Possibly the early model non turbo diff has 5 bolt.
hope that helps
What would be the best bet for a mate of mine with an R33 and the similiar problem to you Cubes... Except his RB30det is worse as he's putting an auto into it aswell.
Whats the best bet for higher ratio R33 diffs.. Would Z32, 3.69 ratios bolt to the standard R33 VLSD centre?
r33/32 all use an r200 diff (meaning 200mm crownwheel)
As long as as the crownwheel and pinion are from a r200 diff then all ratios are interchangeable.
There are heaps of r200 ratios available 3.69, 3.9, 4.11, 4.3 and more...
AS for the 3.69, u need the cw&p from s13's as they run r200's (3.69 auto 3.9 manual)
Edited by Bl4cK32
There are long nose (up to r31, z31 &s12) & short nose (from r32, z32 & s13) R200's & you can only interchange between the right length.
Carlos
  • 8 months later...
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!ย  We are a pack of know it alls....ย  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!ย  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree! ย
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc. ย  It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things. ย  Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing" ย  As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things. ย  It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first. ย  There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one. ย  However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long timeย  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
ร—
ร—
