Hi all
I took my car for a major service (which ended up costing close to $1800) about 3 weeks ago and the guys there told me that I need to replace my shocks since they're all worn out. Anyway, just wondering if any of you guys had yours replaced and how much it cost for parts and labour and what brand?
I need all four replaced and I'm on a budget...not a winning combination :(
Thanks all!
https://www.sau.com.au/forums/topic/113976-r33-shock-replacement/
I sourced them for
$99 each for rears
$122 each for fronts
They were KYBs. Fitted myself so no labour. I bought some universal steering rack boots to replac the dust boots which were about $50 for 4.
Have to get a wheel alignment soon too.
If you want better Sydneykid does biltsteins in the group buy.
Rears you have to remove the trim, fronts are ok.
Budget on about 4.5 hours labour - Probably $400.
I'd say $900 all up.
if your after an upgrade check out the website in my signiture, but if your after stock struts i would say $500 maximum for fantastic condition?
Hi Ryan, it would help your cause greatly if you fixed up the "Janglish" on your web site. It's very confusing and doesn't help the buyer at all.
"Precise control damp valve"
Does that means it's raining?
Only has one valve?
I also notice the same spring rates are quoted for GTR's (4wd) and GTST's (2wd), surely there are different springs rates to allow for the substantial weight differences. Best to put them up on the web site rather than confuse the potential buyers.
:spank: cheers :P
Thanks guys, thats been great info, cause i bought my car in september but don't get to drive too often since I'm working in the city so just started doing stuff to it.
Anyway, Sydneykid, how do I go about getting a group deal for the shocks? I'd be pretty interested in the Bilsteins deal if you could hook something up if they're around the $900 mark fitted. I'm in sydney too hopefully i can get something sorted out. Just need to confirm price, shocks etc.
cheers
    • Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
