  • Replies 66
Posted Images
Man thats sad hey.I was at the servo they filled up at.they (2 other red ferrari's) were together when seen.
Lol,i was also on the side of the road when the lambo was pulled over.We were waiting for the Bellevue Bodyworks cortina to fix it's what looked like overheating troubles.
On the bright side we now a have brake doner.Ferrari brakes!!
by the looks of it the brakes dont work to well.. :angry:
Just to give everyone a bit of insight into the cruise and the cause...
The venue (which ended up being way to small), was the largest space the organiser could find that was a) Privately owned and b) willling to give access to hundreds of rev-heads.
The cruise, many years ago, used to converge on the lighthouse but outgrew the space - and the cops didnt help when they started closing off the parking lots every anzac day.
This year the police stopped the event from being held at the airport - or on any other public owned property - but conceded to it being held on private land - and its really only due to the charity that the police lay off (in general) on the people who cruised to Albion Park. Thats why there was defecting happening at the lighthouse but generally not on the route to Albion Park. I noticed the cop who was booking people parked on the nature strip - but i believe he was one of few police in Albion park who caused any issues.
The organisers sold 500 SuperCruise stickers (all that were printed), all the proceeds of which will be going to charity.
The cars filled the BP Servo, the backlot, the space around the truck repair and wash centre, and a newly constructed warehouse up the back. They calculated they could fit 500 cars and therefore printed 500 stickers.
Its estimated that over 2000 cars cruised into Wollongong - many going to the lighthouse area not knowing that the new location is Albion Park, and many being forced to park on the princes hwy.
Next year the event will probably be held in the same place, but more parking will be available in the field behind the new warehouse. There is also unconfirmed rumours that there will be some action in the form of dyno events and the like.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
