  • Replies 102
i am too...almost finished...have a few pics too...will post them soon
have done the following:
t3/t4
chip ecu and blue screen safc
full exhaust + cat
arc cooler
bov
pod
clutch
400r kit, no rear spoiler (bat wing)
gts badges (finally found them in japan...yay!)
and it getting resprayed in the same wine red colour, hopefully this week
not sure on rims yet
will be getting a tint job too and a retune
will put some pics up soon :spank:
maybe thinking of doing the rocker covers and cooler pipes in chameleon paint
just like me I can olny just get in my room. It's easy to get all the parts but when it comes to using them (putting them on) it can take a long time. this is my car so far
Edited by R32 _ULTIMATE_WEAPON
I have a whole lot of parts in my spare room does that count?? Now I just need someone to put them on my car!
Seriously though I do plan to document what I am doing maybe I should start!!!
Dont document it. It makes you cry. Especially if there are prices. I pull out my car file sometimes, and just look at how bloody thick it is. :laugh:
WHO IS DOING A SKYLINE PROJECT TELL US ABOUT IT AND ADD SOME PIC'S IF YOU LIKE I AM DOING ONE AT THIS POINT TO BUT I HAVE TO GET SOME BETTER PICTURES THEN I WILL POST IT UP
well its kinda a skyline project (well it has a skyline engine in)
a s13 silvia which im putting a r33 gtr engine in
im in the process of modding a r32 gtst sump and oil pick up to fit the gtr engine
Sorry by project I was talking about big things e.g. cool new paint job, big turbo, new engine or all of them.
Yeah i was being sarcastic...
eg.
Cool paing job... What mine not cool enough???
Big turbo... What my TD06 is not big enough???
New engine... What my forgies and full internal work are not good enough???
LOL im just paying....
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
