hey guys
i have a R32 GTS-T and the clutch is sliping hard. im goin to be putting in a R33 Gearbox in soon i just want to know will a R33 clutch fit into a R32 gearbox? and wats a good single plate clutch which can hold about 250-280kw. i drive my car to work so i dont want a Heavy or hard clutch
thanks
bill
I fitted what I was told was a clutch / flywheel assembly for a RB20 onto the back of a RB25 and slotted the engine into an R32 (GTS4), still with std 'box.
It was an Extreme / Exedy HD pressure plate and, I think, a ceramic spring-centre driven plate. It is "heavier" than a standard setup, and has been handling 180 AwkW.
as what everyone else will say
jim berry
jim berry
jim berry
jim berry
jim berry
jim berry
jim berry
jim berry
jim berry
youre looking at around $1200-1500 for somthing you want
This guy should be listened to.
ive been looking around the net and i cant find anything on "jim berry"
anyone know a website or anything about these?
The product is great. Jim has been building them before any of us were born. He has been doing lots of Skylines lately. Modifies them to individual specifications. Give him a call. He is lovely to chat to. You can send it to him, and he'll usually have it back to you within a fortnight. As a woman driving the GTR, its the best clutch I've ever used. Very smooth and quiet around the town (not twin/triple plate rattle), and very tough launching at 8000rpm @ WSID. We have probably done at least 40 or 50 launches in it....and its only just starting to slip now. We are sending it up to Jim very soon to get fixed up before Compak Attack.
RACE CLUTCH
CONTACT: JIM BERRY
ADDRESS: 26 GLADYS STREET
STONES CORNER QLD 4120
PHONE: 07 3847 9999
HOURS OF OPERATION: Monday-Friday: 8.30 a.m. – 5.00 p.m.
Hope that answers some of you questions............ :) Cheers Stacey (the smarter & more consistant half of DiRTgarage).
Edited by DiRTgarage
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
