tonight, filled up the car..... the image speaks for itself...
this hurts when you only get 250km out of a tank too!!!!
what is this world coming to... when are our fuel prices going to go back down? i remember when L was better than $ and that was in premium only a few years ago!!!!!!!
Pitty the government wont remove some tax from fuel......
stuff this im removing the numberplates next time!!!!!!
Ed
https://www.sau.com.au/forums/topic/114160-i-want-to-die/
250km out of a tank? Consistently? How many k's are you doing a week?
Gas-guzzling people like you are the reason why we're using so much oil, which is why the demand is outstripping supply, which is why prices are so high.
https://www.sau.com.au/forums/topic/114160-i-want-to-die/#findComment-2103431
The late news tonight reported that fuel consumption has decreased by nearly 10% over the last three months.
I paid $1.49 tonight. I'm seriously thinking about buying another motorcycle. 3L/100km vs 16L/100km :D
https://www.sau.com.au/forums/topic/114160-i-want-to-die/#findComment-2103460
250 kays out of a tank full,,,what the hell are you doin.
Neil.
same distance in city and highway.... i really think something isnt right with my car.....
only time i got awesome economy was when i was sitting on 60-70 to palmy the other night.......
any hints on increasing my economy...???
scathing.... normally up to 300-400 a week.. so its definately hurting my pocket.......
i could prob push 300km out of a tank but the bosch 044 dosent sit on the bottom and sucks up air....
first 3 days i had the car i was getting 150km out of a tank, one tank a day OUCH
Ed
https://www.sau.com.au/forums/topic/114160-i-want-to-die/#findComment-2103707
something sounds definitely wrong
whether my cars were stock, or worked (32,33 gts-t and 33 gtr) i never returned any more than 15L/100.
Try to keep off boost and see if that fixes your problem ? If it does, then you're a leadfoot. If not, you have other issues which could be related to car running rich or o2 feedback not enabled, etc ?
https://www.sau.com.au/forums/topic/114160-i-want-to-die/#findComment-2103749
Is the car tuned for its mods?
Best get it on a dyno to see what the ECU is doing. I'm not as familiar with Skylines, but my mate's S15 was drinking like a fish after he did the exhaust / FMIC / boost control mods. Once he had a PowerFC installed and tuned, it ran a lot better.
But yeah, lay off the boot and wind down the boost. Its not like you need maximum power around town. If your ECU is tunable, get a more fuel conservative tune.
Also, weight reduction. If there's a whole bunch of crap you don't need in the car take it out.
Umm...jack your tyre pressures up? You'll get a slightly less grip, but you also lower your rolling resistance. Check your alignment as well. Running too much toe can cost you as much as 10% of your maximum power (as one of my tuners noticed on another customer's car), which means your engine has to generate more power to accelerate and hold speed than otherwise.
All this depends on how often you track the car, where you need maximum power and an aggressive suspension / alignment setup. If its primarily a street car that you have to daily drive, I'd set it up for that instead of the once-in-a-blue-moon track session.
https://www.sau.com.au/forums/topic/114160-i-want-to-die/#findComment-2103930
i really dont care that much any more. i'm mostly just sick of people bitching about how expensive it is. in case you hadnt noticed fuel is a finite resource. the people holding the stock are going to want to maximise their profit while they can. the government will be happy with that as they tax at a % not a fixed amount. if you dont like it so much sell your car. otherwise just suck it up. in probably 50% of developed countries fuel is more expensive than here. deal with it. i run 3 cars. 2 turbo'd (1 twin turbo) and the 3rd is a V8. if anyone knows the impact of increased prices it's me.
https://www.sau.com.au/forums/topic/114160-i-want-to-die/#findComment-2104280
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
