Some background.
Tyres: Hankook K104's running pressures around 38psi dry and 44psi wet.
Suspension: Full SK whiteline/bilstein kit
Alignmen: SK's reccomended, -2mm toe on the front, 1 degree negative front, 0.5 degrees negative rear, 0mm toe rear
Driving condtions: 2 full drives of the great ocean road, 25% of 300km at hard style driving. 3x winding road driving sessions 50-60km distance EACH @ fast style driving. Regular city driving
This is a front passenger wheel. The "forward" direction of the tyre is towards the right of the picture
My rears just show a tiny bit of camber wear.
I am not looking to "fix" this issue, just curious why it happends (I rotated my tyres today anyway.
Here are photos of my wear pattern
https://www.sau.com.au/forums/topic/114177-explain-my-tyre-wear-pattern-to-me/
Theory - the rears always have the same "angle of attack" on the road surface. The fronts are forever changing (steering), so they are subjected to higher lateral frictional forces.
Sounds good to me.
Caster change angle, only on the front, causes feathering of the outside edge where the tread blocks are loaded. Doesn't do it on the inside of the tyre because it has negative camber to offset the positive caster.
:laugh: cheers :D
from the look of it youve got to much toe in.
get a wheel alignment. and ACTUALLY ASK them to set it up zero toe
or 2-3mm toe out if you hack up the old pac.:ie. drive it hard
or 0.5-1mm toe in if you just nanna it
also check to see if your caster bushes are ok
if you dont ASK THEM they wont do it. theyl just look at the screen and see if it in the green and straight ahead. trust me i know....
working for subaru. there spec is 1.5-2mm toe in and there tyres always look like that. i set them up at 0 or .5mm out
that way the wheeles arnt fighting each other while cornering,instead one is pulling the other around(ie: the inner wheel is turned out more helping drag the front of the car around.
good for reducing understeer aswell
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
