hey guys im just wondering how many KW @ the engine a R33 GTS-T would get from the following mods.
1. Pod filter
2. Turbo back exhaust and maybe a new manifold.
3. Front mount intercooler.
4. Boost increase to say 10psi or 12psi...
What rough power figures at the engine would i be looking at ?
Cheers guys
https://www.sau.com.au/forums/topic/114179-how-much-power/
1. Pod filter
Cheers guys
if it hasnt got heaps of klms, if it is running well, (plugs, coils,injectors,etc,) you shud get like 180rwkw-200rwkw...depends on ur motor.. ppl have varying results depending on air temp, engine/fuel quality etc
https://www.sau.com.au/forums/topic/114179-how-much-power/#findComment-2103150
