Can anyone give me a heads on how much its goin to cost me to get a core plug replaced because one of mines got a dirty big hole in it!
I noticed i while ago that my car ( r33 gtst sedan, rb25det) was using a a little bit of water, but monitoring my temp and it was all good. But unfortunately today, luckily only 200m from my house i noticed the temo gauge going up around 3/4 and some steam out of the top right side of bonnet, When i got into my garage i popped my hood to find the core plug just above the oil filter was leaking. once the water had stopped i saw i lovely hole in there!!
So as above can anyone give me an estimate on how or if i can do it myself, i do all my own services and have sound mechanical knowledge, but never done any core plug changing
Thanks for your help in advance!
G
I think there's a bung thingy on the block, just above the oil filter, as he says. The drainage bung for the cooling system is on the other side of the block though, so I dunno what this other one would be for, but if it's just a plug, then I wouldn't imagine much. Unless you're saying that there is a hole around the plug? If the plug itself is damaged, but removeable, i'm sure you'd have change from a $20.
Can you take a pic? It's possible that someone with experience knows exactly what you're talking about, but I can't picture it.
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
