They're actually alright cars, zippy for a 1.8L. My sis owned one and I used to drive it around alot, good little cheap relaible car. Don't bother with astra's, my bro has one now and he bought it brand new and has had couple of issues with it already. Toyota engine last you longer anyway than a holden:D
:D:laugh:
https://www.sau.com.au/forums/topic/114210-holden-nova/#findComment-2104898
ahahahahaha, why would u bother, if ur lookn at sumthin like that then at least go for an astra turbo!
Yeah, because a 1990's Nova / Corolla is going to be in the same bracket as a late 90's / 2000+ Astra SRi Turbo, so obviously people will cross-shop them. :laugh:
Why don't you suggest he go look at an Audi S3 or Golf R32 while you're at it?
Edited by scathing
https://www.sau.com.au/forums/topic/114210-holden-nova/#findComment-2105051
Yeah, because a 1990's Nova / Corolla is going to be in the same bracket as a late 90's / 2000+ Astra SRi Turbo, so obviously people will cross-shop them. :)
Because the S4 would be better as it has a boot???
My Granny has one, and she is an old hoon. One of the best cars she has ever had she recons.
https://www.sau.com.au/forums/topic/114210-holden-nova/#findComment-2105508
Tend to chew though CV joints at a rapid rate of knots... :)cheap to replace though. Head gaskets are another common problem. Generally speaking a reliable yet completely unremarkable slice of early 90's econo-motoring... I used to pick these things up for a couple of K and thrash the living bejesus out of them as my daily drivers...
https://www.sau.com.au/forums/topic/114210-holden-nova/#findComment-2105956
I've got a 1990 pulsar at the moment as a daily driver. Costs about $30 a week and i do a fair bit of driving.
I hired a 2004 nissan pulsar the other week whilst in melb, and to be honest, my older car was both faster and about the same economy! and the driving feel wasn't all that much better, in fact very vague and distant the steering and feel of the whole car.
Cars in that sort of range haven't got that much better if you ask me in the last 10-15 years. Now its just about all components as cheap as possible, with the false impression of class with the fake leather look, plastic chromed bits, etc.
https://www.sau.com.au/forums/topic/114210-holden-nova/#findComment-2105996
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
    • Interesting, I've heard complete opposite on my end. Bit of a lottery I guess.
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
