They're actually alright cars, zippy for a 1.8L. My sis owned one and I used to drive it around alot, good little cheap relaible car. Don't bother with astra's, my bro has one now and he bought it brand new and has had couple of issues with it already. Toyota engine last you longer anyway than a holden:D
:D:laugh:
https://www.sau.com.au/forums/topic/114210-holden-nova/#findComment-2104898
ahahahahaha, why would u bother, if ur lookn at sumthin like that then at least go for an astra turbo!
Yeah, because a 1990's Nova / Corolla is going to be in the same bracket as a late 90's / 2000+ Astra SRi Turbo, so obviously people will cross-shop them. :laugh:
Why don't you suggest he go look at an Audi S3 or Golf R32 while you're at it?
Edited by scathing
https://www.sau.com.au/forums/topic/114210-holden-nova/#findComment-2105051
Yeah, because a 1990's Nova / Corolla is going to be in the same bracket as a late 90's / 2000+ Astra SRi Turbo, so obviously people will cross-shop them. :)
Because the S4 would be better as it has a boot???
My Granny has one, and she is an old hoon. One of the best cars she has ever had she recons.
https://www.sau.com.au/forums/topic/114210-holden-nova/#findComment-2105508
Tend to chew though CV joints at a rapid rate of knots... :)cheap to replace though. Head gaskets are another common problem. Generally speaking a reliable yet completely unremarkable slice of early 90's econo-motoring... I used to pick these things up for a couple of K and thrash the living bejesus out of them as my daily drivers...
https://www.sau.com.au/forums/topic/114210-holden-nova/#findComment-2105956
I've got a 1990 pulsar at the moment as a daily driver. Costs about $30 a week and i do a fair bit of driving.
I hired a 2004 nissan pulsar the other week whilst in melb, and to be honest, my older car was both faster and about the same economy! and the driving feel wasn't all that much better, in fact very vague and distant the steering and feel of the whole car.
Cars in that sort of range haven't got that much better if you ask me in the last 10-15 years. Now its just about all components as cheap as possible, with the false impression of class with the fake leather look, plastic chromed bits, etc.
https://www.sau.com.au/forums/topic/114210-holden-nova/#findComment-2105996
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
