hi guys,
correct me if i'm wrong but...
i heard that if you disconnect a certain fuse in the r32 gtr that will change from 4wd to rwd is this true ??
if so, does it have any side affects on the clutch,engine,brakes etc. ??
Thanks.
Yes, pulling the fuse that supplys power to the ATTESA pumps will make a BNR32 100% rear drive in all conditions. And no, it won't hurt anything- the only side effects will be lots of wheelspin/oversteer, less acceleration and dramatically shortened rear tyre life.
Enjoy.
https://www.sau.com.au/forums/topic/114217-r32-gtr/#findComment-2104046
Or you can just switch the ignition off and on quickly as your driving this also switches it to 2WD ;)
Carefull however as it switches to 4WD when you come to a complete stop again, so you could get a severe case of whiplash if you tried to do a standstill burnout :)
https://www.sau.com.au/forums/topic/114217-r32-gtr/#findComment-2105747
sh*t happens anywayz who doesn't enjoy a severe case of whiplash every now and then... :P
https://www.sau.com.au/forums/topic/114217-r32-gtr/#findComment-2113915
Or you can just switch the ignition off and on quickly as your driving this also switches it to 2WD :ban:
Any what about when the steering lock kicks in and you can't get it undone and you crash and die? (or worse, run into me)
V.silly kids. Do not try in the real world.
https://www.sau.com.au/forums/topic/114217-r32-gtr/#findComment-2120012
Oh! you mean when you remove the key completely from the ignition barrel by turning it all the way and pressing in the button then taking it out... THEN jiggling the steering wheel to kick in the steering lock....?
is that what you meant? 'cause it could just be me but I think that would be increddibly hard to do whilst flicking the key back and forth 1 position in the barrel...
Sorry to be a smart arse by the way.
https://www.sau.com.au/forums/topic/114217-r32-gtr/#findComment-2129031
Hahaha, zing!
I got (mildly) pwned.
Yeah, but nah, but yeah- Prolly not a great idea to be turning your car off at speed for other reasons though.
lol! glad you can take it man, well done :thumbsup:
agreed 100% for those that want RWD only use for things like pre-drag tyre warming (on a closed circuit etc) - run a switch to flick between the 2
for those who want RWD only use for things like being the next traffic light warrior or full-hectic burnouts on public roads - If you own a GTR, SELL IT!
Edited by DJ984
https://www.sau.com.au/forums/topic/114217-r32-gtr/#findComment-2132462
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
