Does anyone know of anyone that specialises in fixing th gauges on the dash board?
Last night, notice my speedo is out by approximately 5k according to the avc-r.
the fuel gauge is also WAY WAY out. It's showing it has more fuel in the car when really it doesnt have what it says in it.
Wanting to get this done on Saturday, so anyone know of any, would be great.
https://www.sau.com.au/forums/topic/114229-guage-specialist/
Have you got aftermarket rims?
Noticed my speedo is slightly out vs the PFC, I'm guessing that this is resulting from actual output from the vehicle speed sensors and also from change in rolling diameter(can be out by a significant amount depending on the size you get).
Your fuel reading: Open up your fuel tank and check the fuel level sender thing (big long piece of plastic). It's supposed to be supported on a bracket and if it has come off then it won't give a correct reading. ie - I don't think this is an instrumentation problem.
all this was working perfectly fine before the white dials were installed.
i know its the needles that are out of place for sure!
dan's going to look at this again tomorrow though.
did you do the dials? if you did then you will know what i'm talking about. you would of put the needles back in the wrong place to fix them it will take some time you will have to take it out again take off the clear cover put it back in start your car and put the needle back on the 0 km's per hour with the fuel full your car then put the needle on full. should work.
lol i was in my mates car the other day, and noticed his tacho on the dash, the needle sits on the highest point and when he revs it gets lower, ie idle on 6500 and when flooring it is at 3000 etc i found it so ammusing.. lol
ABLE INSTRUMENTS: ph 3801 1232. They are at Loganholme. These guys are pretty good. I even used them to shorten the speedo drive cable on my R32 when I installed the RB25 gearbox.
since having the white dials put in and having the needles read correctly has been a bit of a mission since then. hence why these 2 are out by a bit.
if you have ever physically moved your speedo needle with your finger or something, its pretty much f**ked
I learnt from experience :miner:
Can you remember the cost??? I know how much my speedo is out, but if it didnt cost much it might be worth it.
At the dyno night im gonna get them to see how close 100kph is on my dial as to what the dyno says...
This is the best way to tell how well your spedo is calibrated...
As compaired to other cars i mean... Cause whos to say the dyno is right?
you could always just wait til I fix it and all will be ok.
Like I said to you, the fuel guage was the only drama because I set it up on under half a tank. All that needs to be done is fill it up and re-set it. As for the speedo, wait til you get it on the dyno and then tell me how far out it is.
When I was a surveyors assitant doing road condition surveys we had to recalibrate the speedo every day due to tyre wear, I was surprised how much it was out each time. This is an extreme case I know but it just showed me how inaccurate car speedos are (we had an an electronic jobby in the test vehicle), we tested it on a stretch of road that had 1km marked on it and at the start point I had to spray the mark on the tyre and at the 1km mark the computer would tell us where the mark should be and then compare to where it actually was.
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
    • Sydney Tools have them for ~$3400. More than the Quick Lifts but these seem better. https://sydneytools.com.au/product/quickjack-7000tl208240v-5175642-7000lb-110220v-portable-light-duty-truck-and-passenger-car-lift-system
