It is definetly not reusable, you are asking for trouble if you do.
It has a layer of metal in the centre with soft material (i think graphite based) on either side, so 3 layers.
I just changed mine, its about $100 from nissan :laugh:
changing to a trust manifold
is it difficult to replace the studs??
ive never done something like that before and the engine will still be in, with everything intact apart from turbo
its not hard to change them, although chances are there will be a few broken ones.
altogether i had 4 broken studs, 2 we got out with an ezi out the other two i had to get a guy in to put helicoils in.
To remove studs all you do is tighten two nuts together onto the stud and unscrew it from the head, same procedure to put new ones in. they become brittle with age(even though they look fine) and there is no way you would leave the old ones in if you have the manifold off already.
when u undo the nuts u do them from the outside cylinders in and the inside to outside when doing them up and make sure they are done with a torque wrench with even torque.
its not hard to do if you are good with your hands, you will need to remove intake piping, then dump pipe and turbo, then manifold, then studs and put back in reverse order. id be happy to give some advice if u need it over the phone just pm me.
pic of helicoiled hole in head
Pretty much look like the above. There are probably other ones other than nissan that would do the trick, and I've seen them at Repco, but I'd stick with the Nissan.
I changed my exhaust manifold gasket over the other week before the rb25 went in..
SiksII is on the money with the procedure though.
yeah all the little bits add up. nissan ones are fine(too late anyway :laugh: )
they are just mild steel studs....
hopefully u wont have any studs that are already snapped off, because then u will need more washers, there are two washers (one thick one thin) for each nut that holds the manifuld on, and if there are snapped off studs then the washers fall off with them.
borrow a torque wrench from someone (i dont have one either i borrowed) because u will definetly need it.
pics of replacing the manifold and in the second pic u can see the two washers i am talking about. on three cylinders(i think) there are thicker thick washers than on the others.
torque wrenches are used because an engineer has specified at which maximum torque the bolts are most effective. if you over tighten then you'll get too much tension in the bolt and it'll eventually stretch and/or warp till it falls off.
too little and bla bla bla etc etc...
check http://www.livesockets.com/quoc/rb/ for info and pics, and look up en-76 that is the page of the manual with exhaust manifold crap.
tightening torque is 3.9-4.9nm or 0.4-0.5kg/m depending on your measurement for the manifold cover. Studs are 27-31nm or 2.8-3.2kg/m.
yokes are all different as someone said, cylinders 3 and for are 22's, others are 24's.
geez its nice when you have an engine manual :):D
27-31 is correct, John, if you tighten the shit out of the studs when insterting into the head i will assure u that u will strip the thread, its alloy ie very soft and easy to stuff up threads :(
its very easy to change the studs dont stress about that, the thing you should be stressed about is if there are broken ones, and if more break when u remove it.
this is the best way (i think)
remove everything in one day
if there are any snapped off studs that u cant get out then get a guy in the next day
refit on a third day
and if u are lucky and nothing is broken then u can do it all in one day :(
btw the guy i used for threads:
Threadman (Colin) (awesome helpful guy)
0414237354
pull the heatsheild off now and have a look for broken studs so u know if u need to order in the extra washers u might need or u will be stuck for them later.
also make sure u have new copper washers for the banjo fittings on the turbo.
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for ?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for  >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate modern almost all cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
    • Let's be wary though, if cranking is so far off, what else isn't set right? Are the dead times set right, voltage compensation etc?   It definitely sounds like it's cranking fuel issues, and holding flat to the floor is shutting them down, but I'm with Duncan that if nothing was changed in the ECU at all, and then this started, I'd be more thinking a leaking injector.   Do as Duncan said, drop the oil and make sure it's not full of fuel.
    • It actually means give it less throttle.
    • Yeah if the goal is to drive something then modifying a car is a bad idea.
    • Wowee! She looks like a major handful out there Pete!
