Like the topic says, need an english translation of the install instructions for this puppy.
We already have the regular pfc install sheet in english but it doesn't explain the finer points of MAP sensor install etc.
Thanks in advance,
Adrian
There are various installation methods for the Djetro Map Sensor depending on the Car Model. For example Evo Lancer CT9A do not have to do anything as the car runs a factory Map Sensor. Skyline RB26 customers must splice twin Map sensor into the Airflow meter harness wiring. Nissan S15 customers must also manually splice a single Map Sensor into the harness. Below are instructions on how Skyline RB26 customers should connect up the Djetro kit.
It appears that D-jetro customers must splice the twin map sensors into the Boost Control Kit harness (or at least use the sme port) to extract positive and negative power.
The signal for each MAP sensor is then connected to Cylinders #3 and #4 based on the Apexi diagram below
For a more in depth diagram and guide please view the correct manual for your car's Djetro version as it will have correct Map Sensor wiring.
i hope its correct however as I have never tried it
Thanks mate.
Your FAQ site was my first stop before even posting here but it doesn't have all the info I need.
Really after the actual book that comes with the RB26DETT version of the D-Jetro in an English translation.
Cheers
Present drama seems to be no fuel pump action :laugh:
Boost control kit turned off, everything set as it should be (as far as we can tell) but no noise from pump. Checking simple stuff now to eliminate that fuses etc but if it's not any of that we're stuck :D
Thx
cant offer much but i know on the evo forums one guy couldnt get his car to start at all with the map sensor not connected properly. do you see PIM voltage for both under MONITOR ?
Problem found. :pwned: GRRRRRRRRRRRR!!!!!!!!!!!!
Injector clips moulded incorectlly and not making contact with injector completely/at all.
Trimmed down injector mounts for clip and all systems go!
Off to the dyno!
Wait a minute! Car idles but is fat as hell everywhere. Injectors dropped to 68%, everything done in the ecu that needs to be BUT sensor check shows PIM1 @ 5.07v and PIM2 @ 2.00V.
That's too different and is showing the ecu that it's under full load - filling the workshop with smoke. :(
Time to check the MAP sensor(s) wiring. AAAHHH!!!
Thanks to Mark Jacobson and Willo for manuals and help so far.
Adrian
Is the actual ECU different with the D-Jetro?
As I see you still have to splice the maps sensors into the AFM wires... and normal power Fc's have the side port?
I think I have seen this asked before and the answer was no.. but can you just buy the map sensor part and make a normal FC run off maps? :)
    • Stock RB fuel pressure is near enough 43.5 psi, so the latency in that table at 31.6 will be close. You can see that 7 or 8 psi equates to about 0.4µs extra latency. So if you wanted to interpolate between the 31.6 and 39.9 psi values you could say you're going up about 2 psi out of those 8, so add about 0.1µs, which is barely worth talking about and is quite possibly wrong because ideally you would fix the latency while running at the appropriate conditions on the dyno, with a wideband sniffing its butt.
    • The pressure, is what you set the fuel pressure to. If you have the factory fuel reg, you'll need to find the factory spec. I don't know it off the top of my head, but someone else might.
    • For others, what GTSBoy states here should be paid attention. Why? Well lots of people play with different engines, and they LOVE to change things like remove AC, or steering pumps etc, and it lends to them needing to move the tensioner too. You want your tensioner, particularly those that are sprung or hydraulically tensioned, to be the first thing after the harmonic balancer, or technically the "last" pulley in the chain. By saying last pulley, I mean look at the direction the crank spins when the engine is running, follow the belt from where the crank is pulling the belt FROM, and keep following that until you're between the last pulley/accessory on the belt and about to reach the crank again, this is the spot where you put the tensioner. This is the area that will always end up with slack. This is worked out exactly the same way for chains too, as the physics is the same for them. The crank pulley is where all the force to drag the belt around comes from. You will never ever get rid of the slack that appears, especially under load. The tensioners job is to keep the belt loose enough when stationary that there shouldn't be out of sync movement in slow movement, and then be tight enough when running, that the belt can't jump off any gear and get damaged. Too tight, bad things happen, too loose, bad things happen. Have a tensioner (mainly sprung/hydraulic one) in the wrong spot, it can't actually do anything about keeping the tension.
    • It was gonna take much longer for the 440cc so I'd thought I'd risk it with the 550cc. They finally arrived and I couldn't wait any longer (I could but I was quite excited after 2 months) and installed them myself. Removed the old injectors, inserted the new and connected everything up. Before starting the car, I tuned the injector size from the factory 270cc to 550cc using Nistune.   This did some of the calculations automatically which catered for the TIM. The latency however did not seem to change. Deatschwerks have the tuning data available for each injector online, and I had a look at it. It has a table which relates to latency according to pressure and voltage (see below image). Nistune requires the 14v value, but I am unsure of which pressure value to look at (my lack of knowledge and experience have something to do with this). The highlighted value is close to my current latency which is 760µs. It is for 14v which makes sense, and the pressure is 31.6 Psi.   I still gave the car a test drive to see how it goes, and honestly it has never felt so powerful before (and some people say the RB20DE is very weak?). I really enjoyed the drive. Side note; The injectors are quite noisy, which someone mentioned before. This does not really bother me however. I will still ask my mechanic to have a look at it and perhaps ask a tuner to fine tune it if they have the knowledge.
    • Also true. But imagine not wanting new injectors? Imagine wanting to use 30 year old injectors?
