Im slowly doing work to my car and now im considering either putting a surge tank in the boot or putting an extra pump in tank.
What do most other guys do?
Can you please post pictures of both setups if you have them.
Regards,
Cristian
Impossible to answer without knowing the power target and what the car is going to be used for.
:( cheers D
Ohh SK!!! Over here over here!!!! :(
32 GTR wanting to push 300-350kw@wheels. Mostly drags, occasional track days.
Saw in fast fours tech issue that placing an external pump after the standard internal pump can flow for big power! Something to do with a higher flow rate due to zero restriction on the standard pumps outlet. This stil doesn't sound safe tho???
Sorry to hijack Cristian :(
:D cheers D
Ok, well im looking at 400rwkw, and the occasioinaly blat around the track.
I know that both are effective (as ive used both in different cars previously).
Im interested in setups as far as finding spots to put a surge tank without wasting to much boot space.
If i use 2x intank pumps, id like to see how other people have made brackets to hold the second pump close to the bottom of the tank or if they have modified the tank to have an internal surge tank.
I used the stock GTR pump lifting to a 2L surge tank and a Bosch 044 from the surge tank feeding the fuel rail. Works wonders and has supported well over 300kw. I got the large kit from GCG, pretty good value imho.
Just replacing the in tank pump with a Bosch 040 now and leaving the single 044 from the surge tank, should support well over 450kw from what I have been told.
Hi mate, my 2.6 Astron is making 400kw, the fuel system is pretty serious, you really should be running a new fuel line up the car because volume will become your major issue. I run dash 10 braided line up the car, and have two Bosch 044 pumps. I run a cell but if you run a standard tank, id be running a 4 liter surge tank, fed by your standard intank pump, and then either bosh motorsport pumps, or a Magna fuel pump. this ensures good pressure and volume. We are talking 400kw at the tyres, 530hp. pretty serious power for a street car that is only going to be used for the occassional track day. If your looking at around 300kw a good intank pump with standard fuel line will do the job.
Edited by Bezerkly
I run a similar setup...except i use the std fuel lines as feeds...dual feed... (to engine and return lines) and run a 5/8 braided line as the new return.
Ive got the bunji tube to run my second fuel line already, so im not to far off the ball then.
currently, ive got a 500hp walbro pump and it feeds 3.5 litres per minute, that seems to be working fine for the power i have at the moment.(last i checked was 211kw)
If i went with the surge tank i was thinking i would use a holly blue to feed the tank and have a bosch pump from the tank to the rail.
My car has 400+rwkw and a single 044 intank. The car is fine on track but I have never run it with less than 1/4 tank of petrol. A surge tank is defintely a better/safer and faster upgrade. I have all of the parts for the setup but still not sure on how/what is the best way to rig it up.
Could you guys post some DIY tips/pics and also let us know how loud the setup is?
Thx
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
    • If it does get a turbo it would blow the JCW Mini out of the water considering how "close" some of the tests were. Then again the Mini would probably get one of them Stage 69 tunes.
    • Next up, the extinguisher is mounted but really only temporary because I ran into clearance problems (the bracket fit fine....until I put an extinguisher on it). It picks up the seat bolt mounts but has long bolts running through 20mm spacers for now Doing it properly requires a bit of quick welding but I ran out of time, this will do for the practice day
    • Family events weekend but a snuck a couple of things in. NSW state champs were down at Wakefield so I got Gordon Leven's to bring some A052s down in the right size for some spare rims I had that "fit" (actually ex-Leaf Nismo.Rays in 18x7.5). Tyres are 235/45/18 so they are narrower than stock (19x8.5s) but I need to keep road tyres on it for daily use for now. In a first, those weird size tyres had been in the yoko warehouse for so long (4.5 years apparently) that they offered 4 for the price of 2....so 4 practice tyres for about $1100. Bit of a bargain for sticker tyres, considering the real purpose of the practice day is mostly to see how the various temps go (and the weather is due to help, forecast 32o). In terms of race wheels, it looks like I should be able to fit 9.5 fronts and 10.5 rears but 18 vs 19 height will be based on what tyres I can get in the right size - good tyres are very limited in available widths in diameters above 17" so some planning is needed. Once I'm sure this car will work I'll order a set of custom BC wheels like I did for the R32, you can get exactly the right width and offset to make the most of the available space in the wheel well (the 32 has 295s all round on 18x10s and they are awesome) Incidentally A052 are asymmetrical but not directional which is good news for rally use if the front and rear wheel sizes are different because I can swap them side to side on the same axle. Directional tyres are a nightmare with staggered size wheels because each tyre is fixed on that corner unless you can get it rotated on the rim (not really practical mid rally in most cases)
