Buy the highest RON rated fuel you can, rather than buying the lower-spec stuff and octane boost it. Octane booster doesn't mix in to the petrol properly, and its only ever designed as a stopgap measure.
If you've tuned your street car to use fuel with a higher RON than what you can easy get at your local petrol stations, then I'd suggest re-evaluating your requirements or purpose of your vehicle.
https://www.sau.com.au/forums/topic/114267-octane-boosters/#findComment-2105035
hi,
what you say makes sense but in this case in australia,I think most skyliners are using Optimax and that's only 98ron.. I think it's 101 in japan(i could be wrong though). And as for the new fuel made by shell which has a bit of ethanol (but has high octane rating),i'm trying to see if it makes sense to safely use optimax + octane boosters.
what are your thoughts?
thanks
rob
https://www.sau.com.au/forums/topic/114267-octane-boosters/#findComment-2105076
If your car has a stock ECU it will run fine on 98 Octane. If you want to use an ethanol blend from what I understand the fuel density is different & you need a tune.
If you have an aftermarket ECU get the engine tuned to 98 Octane.
By way on illustration - when they sold the R32 GT-R's in Oz you could only buy 95 Octane...
https://www.sau.com.au/forums/topic/114267-octane-boosters/#findComment-2105104
Oh, a stock Skyline, or one without a programmable ECU. I hadn't considered that. :(
If the car's stock, then it should be adequate. 101RON would be top-of-the-line fuel; OEMs always design their cars for a wide range of conditions.
If its got a Mines' ECU or something that's tuned more aggressively but can't be retuned locally, I'd probably look at swapping the ECU and retuning instead. I don't like octane booster since there's no guarantee it mixes properly, so I'll avoid it where I can.
I don't think it was designed as a long term solution.
https://www.sau.com.au/forums/topic/114267-octane-boosters/#findComment-2106282
If im going out for a fast cruise with the boys, i try the Nulon Pro octane boost which brings my knock levels down. This is on top of my 98 octane fuel. However, i prefer to fill it up on Optimax Extreme which is 100 octane and brings my knock down considerable.
https://www.sau.com.au/forums/topic/114267-octane-boosters/#findComment-2106835
  • 3 weeks later...
hang on... i thought with Optimax, your car shouldn't knock anymore?
https://www.sau.com.au/forums/topic/114267-octane-boosters/#findComment-2156957
a higher RON is just a higher resistance to preignition (knock).
tune your car to 98RON (Ultimate, Optimax, Vortex, Synegy) and add a octane booster if you want when you venture to the track or go for a fast cruise with the boys just as an added safety factor. otherwise yeah, "re-evaluate your requirements of your vehicle"
https://www.sau.com.au/forums/topic/114267-octane-boosters/#findComment-2157096
hi,
i'm in melbourne. A few months ago,i enquired and found that Caltex has yet to have 98 ron fuel in melbourne. Seems their Vortex are 95 or something. Has anything changed?
thanks
https://www.sau.com.au/forums/topic/114267-octane-boosters/#findComment-2167733
    • I keep seeing supercharger kits for these listed on marketplace 😂
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
