Obviously 1989 models are now coming up for sale.
So what do you think about these? I would imagine these would have be close to stock after May but still.
Maybe 1990/1992 models will be coming up soon next year. They certainly will not be a cheap car to run but certainly fun.
I am wondering :D
T.
https://www.sau.com.au/forums/topic/11429-buying-15-yo-r32-gt-rs/
15 yo rule has nothin to do with what SEVS is implementing. Meaning u can import a car with wateva mods u want, they dont need to be destroyed, and ur only concern is small things like changing seatbelts, mirrors, and installing side intrusion bars if needed. Once that is done, u need to make sure the car is roadworthy and will pass through your govts car centre place (ie Adelaide = regency.)
Hope that clears up a bit for you.
Oh and 89 GTRs are horn. Wait for a heaps modded one and u should get it real cheap. Somethin in Bayside Blue would look awesome. Imagine it.
yup u can bring one over now if u like and when it comes to exactly 15yrs from the date that the car was made,u can get it complied/ Engineered. Or u could get it now,do all the work needed to get it passed,then once its time all u have to do is take it there,get it ticked off and off ya go :D
if i see one for cheap im gonna get one,but i just want a normal turbo,cause i just want rwd
That is so wrong onfo it isn't even funny.
Check your facts before you post .
Cheers
Ken
Cheers
Ken
Wat ken is sayin is that U CANNOT bring in a 15 yo car now if its a 89 GTR for example. U have to wait until the beginning of next year, then submit ur DOTRS import approval and tick 15 or older car.
U cannot simply bring the car here now, and get the car ticked off when its 15 y.o
So yehs i agree with Ken, know ur facts before u post somethin
Guest ylwgtr
14K there or here ?
Cheers
Ken
Ken, it was there...but that price (approx $14,900) was the cost all-up to get it over here (excluding ORC)...
oh and also excluding a "small storage fee" to keep it in Japan till next year so it's eligible under the 15y.o. scheme...
still cost you 2000 to get it complied, engineered
also 14k is a great price for the first month(so you pay17k on the road)
until you factor in the engine rebuild 7-10k
then you might realise wat value this car actually is
with the rebuild you have paid 25-27k (for a 89 model form jap)
then the price seems about right
pete
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
