Hi guys
I seem to have a problem with my rb20det
When i first turn the car on, it starts ok, but then the revs are around 0-200rpm and then I tap the throttle and it the revs go up nicely to around 900-1000rpm for warming up.
I take it for a drive, come back, or whilst driving I am stopped and the revs are about 0-200 to 500 and I have to tap it for it not to stall, like when Im stopped the battery light, hicas light etc turn on cause the car is about to stall so I keep the revs up... then when I've taken it for a drive, park it up and let it idle, it is perfectly 900rpm or there abouts.
Could anyone know what is going on or experienced a similar problem?
Battery is fine, alternator is fine. could it be throttle position sensor or AFM related? Could anyone please help?
https://www.sau.com.au/forums/topic/114296-low-revs-when-car-is-stopped/
I'm going to take off the pod etc and check if has any cracks, because it isnt secured at the moment. Ive also found that if I move the pod up it changes revs and then I move it back down to current location where its hanging the revs die a bit, so there could possibly be a tiny crack in the piping there.. I will check it out when I add the bracket for the pod filter
ok well everything is disconnected
i dont know how the afm is supposed to be clean? is the top part of the afm black part supposed to come apart or what on a stock rb20det afm?
also i found that when the afm was removed, there was oil inside in the pipe , should i remove this pipe and clean it..
bit hard to get to the end of the pipe where the intercooler piping is covering it all :(
just try and clean it as much as you can with the contact cleaner, the afm is one peice, dont try to fiddle around with it or you can stuff up the AFM, try and get most of the oil and residue off it as possible, dont touch the "hotwires" at all. just spray
if there is alot of oil, could be a shafted turbo, but could be just years of buildup
it should fix your idling problem, i try to clean mine every few months
good luck
ok well afm cleaned thorougly
and then i removed piping
cleaned tps as it was covered filthy with black dirt so its nice and shiny
took it for a spin, perfect, no idle problems
i came back, to adjust the revs to make them lower (it was idle at about 1000-1100rpm) and then i lost the small nut under the throttle body where it has a small screw head to adjust the revs (i think thats where it is).. not far from the aac valve
im about to find a new nut for it and put it on, but i took it for a spin without the nut and the revs were back to playing up again, does anyone know? will respond when i got the nut in and its all tight
ok everything is bolted back up togethor
took for drive, let it warmed up
still has the same problem, come to a stop whilst driving and then the revs drop really low and battery and hicas light flash and come on
i have to tap it and then the revs are perfect 800-900rpm just under 1000rpm
could it be the little gold tube (iac solenoid?) which needs cleaning? almost impossible to get the bottom screw from this part (one with the brown adapter connected to it)..
or should i try a mates afm, which i know is working on a rb20det.. since this could still be afm problem?
edit - also when the revs drop down and idle becomes low, there is a kind of screeching noise coming right from above the plenum, where it says eccs. but when it idles fine the sound isnt there. anyone had this problem?
Edited by tiesto
aac valve was cleaned
put it back in and still no luck
i disconnected o2 senser, a little bit better but still wants to stall
when i approach a corner/intersection in gear and slowdown in gear and leave it in gear with clutch in, it doesnt stall
its only when u come to a stop or turn and roll it in neutral and then stop it starts to drop out so have to tap it to keep it up
oh and i replaced the afm with a working rb20det afm i know of a mate let me borrowed , still the same
any clues?
yeah i've reset the ecu
disconnect battery
hold brake for 30secs
and then start it up again
it only happens when im driving the car and coming to a stop or turning at intersections. gotta tap it to keep revs up but then it stays perfect 900rpm idle
could it be throttle body getting stuck and having to tap it to get it up again
i've cleaned throttle body/tps/aac valve i might try the throttle body again
im in the boot now
checking out my fuel pump
where is the fuel filter?
i'm going to ground the fuel pump's ground wire to the chassis
that way you can get fuel all the time and when in idle more fuel will come in i read it in another thread.
disconnect battery
Check TPS is still working and is set in the right position. It also sounds as though the idle bypass screw within the AAC valve isn't set right. What is meant to happen is that when you come to a rest the TPS should register 0% so then it sets the right duty cycle on the AAC valve to gain the desired idle rpm (850rpm). Now if the TPS doesn't register closed throttle then the AAC valve will not try to control idle and hence stall. The AAC valve itself should only control about 20-25% of the total air thar the engine needs at idle out of gear AC off, the bypassed air will deliver the remaining air required.
when i start it, the car finds it very hard to find revs
by this i mean when i turn the key it ignites
revs go from 0 to to 100 then prob 200, back to 100, give it a tap and it goes up to 900, on cold starts you have to keep tapping it after it goes to 900 sometimes it drops back straight to 0 then 100 to 200. then after its warm it idles perfect 900
coming to stops/intersections does the same problem.
will check out what you said, rob82, and will reply
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
