What DOTARS says goes. They're the authority responsible for this stuff, so if they say you can get compliance, you can get compliance. Keep a note of who you spoke to and the date just in case anyone contests what you're saying. I think the RAW's wont give you any trouble if you've got DOTARS behind you.
Just a side note, now that its going to be complied under SEVS, that means it has to come back to stock. Have you got much aftermarket gear on there?? Would be a pain to have to take whatever you've got off, but I suppose it wont matter - you'll be too happy that its even getting complied :(
Good luck again!
Blacky
Just a side note, now that its going to be complied under SEVS, that means it has to come back to stock. Have you got much aftermarket gear on there?? Would be a pain to have to take whatever you've got off, but I suppose it wont matter - you'll be too happy that its even getting complied :D
Good luck again!
Blacky
Haha yeah im very happy its getting complied, but now its gonna be a fair bit of work; and i did get the guys name that i spoke to;
Fuel Rail
Injectors
Fuel Pressure Reg
HKS Cooler
Piping kit
Front bar
Pods
Yeah theres a few things there. She'll be rite. :(
Thanks again.
Fuel Rail
Injectors
Fuel Pressure Reg
HKS Cooler
Piping kit
Front bar
Pods
Thanks again.
Very good, shouldnt be too hard at all! I dare say (and ppl correct me if i'm wrong) that *some* RAWS may overlook the injectors if they look stock and fuel pressure regulator too. Don't quote me though!
In any case, easy job.
Blacky
Sorry for a bit of a thread hi-jack.. but..
I purchased a 1990 model Laurel uncomplied that came in under the 15 yr rule.. I have a copy of the approval and have checked its autheniticy with DOTARS. Am I going to need a deregistration certificate or the like as well?
Everything that dotars said is correct but one thing they missed is that you'll need the deregistration certificate from japan.
But i asked them that question: 'do i need dereg papers?' n they said no. I thinking that the dereg papers are a new thing?? Like since the introduction of the SEVS? n that came in 2003, and car was brought over in 2001?
(Getting more and more confused every minute)
every car that i have complied needed the de-reg. and that was under LVIS/CPA and 15yo. hell i needed the de-reg to even get the VIA under the 15yo rule as that is what shows date of first registration (to prove 15yo).
i needed dereg papers for my '89 gtst.
But does it not matter that my car was brought over amost 5 years ago?? I was thinkin maybe that the regulations were different back then, so the original buyer of the car from japan never requested them (dereg papers) because they werent needed back then? Apparently you didnt need them back then, now you do.
Ill be faxing a letter to DOTARS anyway, to get the original copy of the Import Approval and see where that gets me.
Thanks all.
Mat.
mate it doesn't matter what we all say - dotars have the last say, and what they say goes.
for what it's worth, my dereg paper was this crummy third generation photocopy, i could barely read it. i don't even know how deeply the rta read it.
i am also of the opinion that dotars will probably be helpful in this case, if you just explain what's going on. be sure to keep us posted.
  • 4 weeks later...
Well, good news all...the car is now in the process of getting the compliance work done. It has been a very long and stressful time, but it will be well worth the effort, everything back to stock wasnt so bad after all. So it shouldnt be too much longer before it hits the road!
Thanks for everyones help and info, much appreciated.
Mat.
A place in Bayswater called Japanese Performance Vehicles. They are apparently one of four workshops in VIC that can do this work.
Yeah I know them, they are compliancing my R32GTR when it arrives next month. They also complianced my mates R34 GTR a few weeks ago. Nice bloke.
Yes VERY nice bloke, has been most helpful during this difficult process. Was your mate satisfied with the work they did?
He's really happy with the work, good clean job and the fact it was completed relatively quickly without any fuss. Out of everyone I phoned to get quotes for both his 34 and my 32 this guy didn't try to sell the earth and gave us a price and was really helpful.
I just can't wait til i get my 32. Not long to go.
All the best.
  • 3 weeks later...
Well, the final chapter to the story.
I picked up my car this morning, fitted with the Compliance Plate and all the stickers and everything...it all went well.
Sam at JPV sourced all of the paperwork that was needed to do the compliance, we did end up needing the Japanese Deregistration papers, but he sorted it all out.
Im so very excited, now all i have to do is get a RWC and reg. and my beast will be hittin da streetz...
Good luck to all that are/will be in the process of Compliance, and thanks for everyones help,
Mat.
P.S Cannot recommend more::>>> Japanese Performance Vehicles, Bayswater, Vic. Talk to Sam.
    • I got the four AN10 fitting welded up to the cam covers and started up making the head to sump breather/drain lines. The front passenger side cover I used a 45 up top and a 90 at the bottom into the stock VCT head drain spot (3/4" BPST to AN10 adapter) thats unused on the RB25DET NEO with some speedflow flame shield to protect it from the manifolds heat.   back passenger side was a 90 up top with some flame shield and 45 at the sump end. The rear drivers is 45 at both ends   the front drivers fitting is capped off for now but ready to go if i want to try moving the breathers around. I was told by the fabricator to leave all the welds raw for now to make sure there are no pin hole leaks. A lot of cleaning up, re bundling looms and degreasing to go as well as final assembly on the cam cover baffles. The first real test will be 28th March at a Circuit event. added complexity and more spots for leaks but overall looks relatively neat imo
    • Yeah i think the dash needs to come out. To get the loom or maybe just climate control and radio cluster. My mirrors are done i think the motors don’t work so well after flood haha i need the ac fan, you said you wanted to keep it for your 31 and interior loom not including boot. The wiper motor. I’m not sure how good the window surrounds are on the exterior on the pintara.  I will message you to get your bank details shortly
    • Just another barrier put up to stop cars being modified. When we're all driving Chinese sewing machines, you won't want to modify it anyway, and you'll likely already have slashed your wrists and be locked up in a padded room for your own protection.
    • Yes, but no. I wouldn't want an IC7, because I think they are ugly, cramped and most of the displays I've seen are garish (and granted the last bit can probably be avoided). I wouldn't want to pay for the UC10. Probably wouldn't want to pay for the IC7, for that matter. And, it's an R32. I have cable drive speedo. Although, thinking about it, that's not a big obstacle, because at least I can throw the electronic sender back into the R33 box and then find a way to emulate the original (R32 or R33) speedo head's conversion of the saw-tooth AC speed signal into the square wave that the ECU wants, without the 1990s approach of hiding a gutted speedo head behind the dash. (another Arduino project, no doubt). I like the technical aspects of the big digital dashes, but I aesthetically and just general originality and feel-wise, like the original dash enough. More? Yes, more. If I had a UC10 I'd want to make the dash look as close to the original one as possible most of the time, and only flash up "DANGER TO MANIFOLD" when it needed to. But the other aspect of the 3-DIN slot digi gauge that I'm contemplating is that I'm a tinkerer and can barely resist a project, even if I don't need to add another to the list of unfinished ones. And I think there's enough precedent of others out there that have proven which equipment works (ie, is not washed out, or slow, or prone to failure, or all the other problems that can afflict such a project). I'm not quite enough of a micro-controller tech head that I know the best way to approach all of these decisions, and so striking out on my own to achieve it years ago would have led to unhappiness. But now, it seems like a project that I can actually achieve on the first or second go, with only a few sleepless nights. And that's why I'm actively thinking about it now. I would much rather have a thing in my car that I made from more-or-less scratch that does what I want, rather than something that someone else made that does some of what I want, not other stuff I want, and/or annoys me in some fashion. If I'm going to be annoyed, I need it to be my fault, so I know who to blame, and who needs to fix it. As an example of that - I have surveillance cameras at home. No, I did not go buy a kit with a DVR and 4 or 8 or 16 off-the-shelf cameras in a kit. No, I did not want to use any sort of could service to record or access the feeds and recordings from outside the house. No, I bought my chosen cameras directly (from China, lol) and built the DVR myself using a couple of different (ie, this was attempt 1 and attempt 2 to get a system I liked) software packages, running on Linux, with the server being a virtual machine running Proxmox. I found a way to offload the image recognition part of the system to a dedicated AI processing board (a Coral TPU, for anyone who cares) with the hardware passed through to the server on the VM, motion detection offloaded to the GPU, all storage is local in the home network, accessible from outside via my own self-hosted VPN). All done so that I could seal off the Chinese cameras in their own network where they can't access the internet and dial home to the CCP and backdoor my network. All things that you can't have if you do what is commercially available. And even with all the f**king around it has still cost a fraction of what it would cost to buy commercially.
    • ..could be worse... but out here, renting private affords some luxuries ...we've even been told the Sept dateline isn't critical, and I'd rather move stuff in the cool of winter, than slogging it out in the heat. Recall we were talking about the million dollar view this place has?...that's what he got for it... (won't be so nice when the quarry happens at the back in the future...lol..)... ...cool, I'll stick the wiper motor in a wee box...umm.... the pinny is GLX trim ~ I think that's about as close as it gets to Silo spec when it comes to the S2 pinny...ie; electric mirrors etc etc...dunno about the trip computer/wiring...I do electronics repair, I'd be willing to take a look at it for you. As you saw, all the dash is there in that car..and thinking about it, it'd be easier to pull the whole center section out, rather than just the ashtray and rails, but your call...
