The toruqe you need to devide by your diff ratio to get the real figure... Cause you diff multiply's the real figure...
So take your 1200 odd and devide by diff ratio and you got the real figure...
I thought you ran 199rwkw??? How did you end up with 178??
  • Replies 194
Posted Images
Damo was reading speed not the power line, lol!!!
What is the standard R33 diff ratio??
Mine is 4.11
My reading was over 1900nm of torque... So when you devide it down it came to 482nm of torque...
As you see im my signature i have 2 power settings... I have now programed the boost controller for both... So if i need a little more power or am doing another dyno night then ill use the 17psi setting...
250rwkw here i come... I need cams...
Muhahahahaha..................Just goes to show what can be done with a stocka (wifes car) and a very tight budget!!!! Many thanks to Chapman and Chapman and Elite Racing Develpoments!!! AFR's couldn't be any flatter!!!!!!
I pulled 169kw...but the graph is indicating some timing issues, so glad to know that's why I'm down on power compared to Pete...damn you Pete, Damn you!!!! :O
Mine is 4.11
Awww I only got 315nm :ban:
Oh well luckily I have all the parts I need to remedy that situation!!!
The race is on to make 250rwkw :O
Morning Guys :)
A big thankyou to Col and Mud for organising this event. It was a great turnout and we even had 2 people sign up to join the Club :D
Was great to catch up with everyone and to see the 'competition' on teh dyno :ban:
Thanks for a great night :O
Cheers,
Karen
Hey guys, was an awesome turnout. I was surprised to see so many there!!!
Thanks Damo for your wonderful reading of the screen... what have I always said about never trusting a black man... who's name is Damien :O
But seriously, we were talking on the way home, and Andy's gonna head into motsons today to have it run on a Dyno Dynamics in shoot out mode (that's what it's always been run on) to see what's going on. Faaaaaaaaaaaaark can't WAIT for our workshop to get it's ass into gear and do the upgrade :D
Wonder if we'll beat you to the 250 col... :ban:
good turnout and well organised.
good to come along and chat to a few people.. pity my car was about a week and a properly adjusted clutch off :O
.. i reckon the race should be to get a sub 13sec 1/4 mile with at or under 250rwkw.. :ban: .. game on
Hey Gordon was great to catch up with ya again... Long time no see...
Was gonna call ya yesterday after i was finished with Matt Spry, glad you came along...
Yeah im in for the sub 13 challange.... I just need tyres for the launch cause i have the trap speeds 103mph....
Remember Anna what ever he reads on motsons dyno will be the same increase for the rest of us... In terms of a percentage... So if you ran 179 last night and you run 200 today and i ran 198 last night then in theory i would run about a 224rwkw area... Post up what he gets, will be interesting...
Guest
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
