Remember Anna what ever he reads on motsons dyno will be the same increase for the rest of us... In terms of a percentage... So if you ran 179 last night and you run 200 today and i ran 198 last night then in theory i would run about a 224rwkw area... Post up what he gets, will be interesting...
I dont want to get it done so I can come back and say see now I go to the top of the class, I just want 2 things
1. A more easily comparable result (Shoot out mode is the best we have) for before and after comparisons
2. A better graph to read...the scale they used for the power curve shows nothing, everyones was a flat line pretty much!!! And once again I want that for before and ater comparisons
So dont worry I wont be comig back claiming I beat anyone!!!
  • Replies 194
Posted Images
Unfortunately for me on my way home i blew a head gasket. Nothin major, just a slight little leak. So the second i noticed strange smoke out the back i turned the thing off and got it towed. should be back on the road soon :P
btw i was the guy with the piss weak rb20 silvia. haha
Col..1900N-m of torque..that's solid! At how much rpm did u hit max torque?
Any idea wot my final reading on torque was after the conversion? Got some ?? about the printed dyno graph...lol different from wot i usually see.
Anyway cant wait to see all the pics, videos and results from everyone that went on the dyno...
Cheers~ :D
Unfortunately for me on my way home i blew a head gasket. Nothin major, just a slight little leak. So the second i noticed strange smoke out the back i turned the thing off and got it towed. should be back on the road soon :D
So it was u how left coolant on the dyno...
Cheers~ :D
Pics are on page 8...
What was your final Nm reading j-boy???
If I knew you guys were racing to 250rwkw I would have run mine.
Col...I thought yours would have more torque than that...after all it is an RB25...mine's only a 20 and I make 620nm. There did seem to be some inconsistancies with that dyno though. Like Dan's 34...should have been making 175 at least. John's...properly tuned or not should still have cracked 220. Not saying it wasn't accurate, just a bit suss on it.
Col, yours should be somewhere in the vacinity of at least 500nm of torque.
Does not matter how the dyno reads... up or down... Impossible to say who dyno is perfectlly accurate...
You missed the point of the night dan...
It was to compair cars side by side on the same dyno... Plus to have a meet and greet... Bit if fun...
I dont care what kw and torque i had on their dyno compaired to others... All i know is that i drive a fat torque monster which will get me in enough trouble one day...
Anyways... I am only using the final figure divided by the diff ratio so it is dependant on thier dyno... But then i always knew i had heaps of torque...
Remember kw mean sweet FA... Its the torque that gets you down the quarter faster...
IMPORTANT
Can all of you who ran your cars pm me you figures...
I need the following
* Outright KW at the wheels
* Outright Torque at the wheels
* Speed at which highest KW was reached
* Speed at which highest torque was reached
As i have not got an email from them as yet and i want to wrap this up... So i can get onto the DVD....
I started it and the laptop crashed and ditched the clips... But i still have them on the camera... So here goes another hour of capturing and abother 20 gig... :D
DOU33....haha yeah guess i needed to clear some carbon....weird thing is that i just had a brand new 3.5 metalcat put in less than a mth ago... :
9krpm...thanx...guess its not too bad, my car was never built fer outright power anyway~haha dude if u were there u would smoke me with yer GTR! Hoping to see yer car on the dyno one day manz...My AFR was mostly on 0.85, dont know wot units this is on actually, but previous dyno i was running AFRs of about 11.7 Yeah catcha up soon yeah....maybe this weekend... :D
Yeah i went just to have a look at first n then decided to put my car on fer a run just to check how it's running...got to speak to a few people and was great getting to know new people, hoping to get to know more of u guys in the future. All in all, think it's something fer people to meet up n just have some fun. :)
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
